3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Water fountain ramp toy
Step 3Build it
Build it
Begin by cutting one of the main tubes to your desired height. I made mine 36". Next determine the slope you want and cut the second tube to height. I made mine 30".
Cut out two circular base fittings from your wood to fit snugly into the tubes. (see photos) Glue/screw them to the container in your desired location. If you use screws make sure your glue creates a nice seal so that water will not leak out the bottom.
Now you can measure your length for the ramps. Mine are about 31" for the first three, and 18" for the last one. Cut them a few inches long because you will be shaping them to fit the curve of the inside of the main tubes.
Next, measure down and cut the holes into the main tubes for the ramps. (see photos) Test fit your ramps and shape the 3 ends that need to be longer inside the main tubes. I didn't make the insides smooth enough and had to add some caulk to make the water flow better, but since you are reading this you won't make that same mistake...
Cut another cap insert that fits snuggly in the top of the main tube as seen in the photos. Drill a hole in the cap the size of your water pump tube. Run that tube down the pipe and secure the cap from the outside with some small screws. Fit your water pump in the base connect the tube. Drill holes in the bottom of the main tube around the area that the water pump is located and cut a hole large enough for the power cord to exit.
To hold the ramps to the main tubes and give it strength. I drilled and attached small screws in each end just wide enough apart to fit the pvc.
Using bathroom caulk seal up the top cap so that water doesn't leak down the sides and holds the pump tubing in place. Put everything together, fill the base with water, plug in the pump and give it a test run. If the water doesn't follow the ramps down, just use a little caulk to seal things up as needed.
Paint everything the color of your choice if you want to make it look a little more like a toy and less like pvc tubing.
Get a few balls or floating toys and call the kids over to play.
When you are all done with it, simply take off the ramps and lay everything down into the container. Put on the lid and store until next time.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
118
Author:Stryker
