3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Water pipeline dan cocacola table lamp
Reused water pipeline and recycle cocacola bottle, can be connected with the pvc pipe. This is the nice and contemporer lamps, the alternativ lamp, make your room more interesting and different fronm another.
Bambang PE, Bogor - Indonesia
www.sensatiocraft.blogspot.com
Step 1Collect reused water pipeline,recycle cocacola bothe, cable, fitting, knee pvc,pvc pipe,boxes
6 comments
Jul 8, 2011. 1:32 AMwobbler says:
Using an energy saving mini-flourescent light bulb would be safer than a mini incandescent and would probably provide more light.
I could also see a neat touch being to add a rotary switch or dimmer which is connected to the tap somehow.
Good use of re-usable bits and bobs!
Jul 11, 2011. 1:26 AMwobbler says:
Thanks for the website ref, it was interesting and had some good ideas!
Sep 2, 2010. 8:03 PMemerson.john says:
This is a clever re-purposing of material. Good job! I have most of the same materials laying around so will make one myself using LEDs.
Sep 26, 2009. 3:20 PMSimons_Pure says:
It could be advisable that you list not to leave the lamp on for long. Hot bulb with very thin plastic around it could cause problems. Other than that it's a good instructable, try re-writing it to make it a little more clear though. Don't bold everything and list the items needed a bit more clear.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:bambangpe(www.sensatiocraft.blogspot.com)
I'm worry about my earth, so many plastics spread out in my sorounding, although still usable, but people don't care. By this sites and this program, let us save the earth. Bambang PE, www.sensatioc...
more »
