3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Water proofed temperature sensor
Seal a Microchip TC1047AVNBTR temperature sensor into a plastic tube to make it impervious to water and most other liquids. This is intended for use at low temperatures. The photo shows the completed probe, powered by three AA cells, measuring the ambient temperature as 30.9 degrees celsius.
Step 1The Sensor
The Sensor
The figure, copied from the data sheet, gives the salient characteristics of the TC1047 temperature sensor manufactured by Microchip. The supply to the sensor can range from 2.7 to 5.5 volts and it converts the temperature to a proportional voltage with a fixed offset of 500 millivolts.
Thus this sensor is ideal for measurement where the result is to be interpreted by a human. A multimeter in it volts range will show the temperature with an offset of fifty. Zero degrees Celsius will result in 500 mV. 100 degrees Celsius will result in 1.5 volts.
Since I was making this to investigate the temperatures in and around a refrigerator, in order to troubleshoot the making of ice cream, I decided to encapsulate the sensor in plastic, it being easier to manage than metal.
The downside is that it might not resist heat very well, as the plastic tube becomes soft if immersed in boiling water. The plastic does not conduct heat very well and so the sensor takes some time to respond to the applied temperature.
If the above points are important to you, there is another instructable on the same subject: http://www.instructables.com/id/Waterproof-a-LM35-Temperature-Sensor/
1 comment
Apr 22, 2008. 4:53 PMGorillazMiko says:
Nice Instructables Robot patch. :-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
70
Author:neelandan
Employed as an Engineer in Electronics. Interested in building small circuits around tiny chips (the electronic kind).
