3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Water-proofing a Servo
Hi, this is my first instructable so feel free to give feedback. There are many different ways to water-proof a servo, some of which are very effective but some are for a quick, non-permanent water-proof.
For Robotics, servos are a lot more useful than motors but for going underwater they both are useless so need to be "water-proofed" so in this I'ble I will show you how to do it with the most efficient method.'
www.societyofrobots.com/
Step 1Water-Electric Info
Water-Electric Info
Servos
The hobby servo in the last 5 or so years has become extremely popular among robotics builders. They are cheap and easy to use, but there is one issue with them - they aren't waterproof. Whatever people claim, servos are only water-resistant. This means that splashing water on them is fine, but full water immersion is like drowning cute kittens (very bad). This tutorial will list several popular ways to waterproof servos, then I will go into the best method (the SoR method) towards the end of the tutorial.
Servos are Only Water Resistant
Taking apart a standard servo you will quickly notice thin rubber rings around the edge, as shown at the bottom.These rings are there for near water-tight seals. Your main concern for water entering your servo is actually at the output shaft. Sealing the output shaft is always the most difficult part when waterproofing motors, and people do crazy things like magnetic coupling, etc. But as a hobbyist, using the most cherished of robot actuators (the servo, cough), we will have to do this low budget. But note, when I say low budget, I also mean very reliable . . .
Electrical Resistance of Water
The very first question you should be asking yourself is what type of water your robot will operate in, as it will make a huge difference in your design.
Pure water is a near perfect electrical insulator - meaning that it conducts electricity very very poorly. If you were to drop your computer into a tank of pure water, your computer will still work! So why is water normally bad for electronics? This is because in water there are impurities called ions, such as sodium or chlorine or whatever, that transfer electrons.
12 comments
Aug 6, 2010. 6:51 AMnzkiwi says:
My experience with Superglue is that over time it is water soluable.
Jul 26, 2010. 5:18 PMDr. Tarantula says:
soooooooo tottalllllly aaaawwwwwwwwwwwssssssoooooooommmmmmmmmmeeeeeeeeee!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1 im going to do that asap
Jan 23, 2010. 4:32 PMshax says:
Make sure the RTV you use is non-corrosive.  Some RTVs will corrode electronics.
Mar 29, 2010. 6:04 AMslomobile says:
RTV stands for room temperature vulcanizing.  RTV is a common generic term for silicone that comes out of a tube as a gel and when exposed to air firms up to a rubbery solid.  Epoxy is something different.  Epoxy is not silicone, it typically comes in 2 liquid or gel parts that are mixed equally just before being applied.  Check the label because the proper ratio is not always 1:1.  Epoxy dries to a permanent very hard solid plastic.  So epoxy and silicone RTV look the same when being applied but the final result is quite different.  Yet either can be effective for waterproofing.
Jan 30, 2010. 4:43 AMsharlston says:
no i think its a type of robot
Jan 30, 2010. 10:02 AMsharlston says:
oh im sure ive heard the words rtv used before in robotics my bad
Mar 28, 2010. 6:55 AMBlueSuneLIght says:
Very nice, I thank you this is some info I needed for a project I am doing.
Trying to build a Submarine for the dam where I live so I can see what the yabbies are up to down there.
Feb 5, 2010. 10:40 AMtrike road poet says:
I sail model boats and have used the following to seal my servos.  I remove the lower servo case section, and paint the electronics, the bottom of the pot, and the motor case and the case around it with Freeman 1035T Brushable Mold Making Polyurethane Elastomer.
It is an off-white color and easy to see, so you won’t miss in the coverage.  Paint the PC board on both sides, and over the cabling to the board.  Once everything electrical is covered, let dry overnight and then reassemble the case, super gluing, (If you like?  I’ve found that working the servo case into the boat often broke the glued area.)
I simply paint a thin layer of the Freeman 1035T on the o-ring areas, and put the case together and screw it together firmly.  The o-ring on the top is a good idea, as well as lubing it with waterproof grease, like automotive Lithium-based wheel bearing grease.  I strongly suggest relubing the arm O-ring each time you go out, (about 3 minutes at most!)
Check out Freeman Supply, a lot of neat stuff for a host of creative projects, and they have a great customer service staff that will help you answer those strange question folks like us come up with!
http://www.freemansupply.com/Freeman1035TBrusha.htm
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:frodobot
