3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Water Rocket
Step 4Glue the Fins
Glue the Fins
Now, if you plugged the glue gun in earlier, it should be hot by now. If you didn't, you'll have to wait for it to heat up.
To glue the fins on, simply choose a side of your fins that you want to glue on. (Use the same side for all of the fins.) Then, put a good bead of glue on the fin and press it onto the duct tape. Make sure that the fins are all the same height and that they are parallel with the rocket. If they are tilted, the rocket might spin.
6 comments
Apr 5, 2011. 5:14 AMEmziii says:
Hey do u hav 2 use a hot glue gun? If not plz tell meh sum otha glues i can use. Would duct tape work okay?
Apr 5, 2011. 5:17 AMEmziii says:
Please answer asap
Aug 18, 2009. 6:47 AMgigocorp says:
Do you put the duct tape on to keep the hot glue from melting the bottle? Or does the duct tape have a different purpose?
Aug 18, 2009. 8:18 AMgigocorp says:
Oh, I see. Nice idea. A while back I tried to make one and the hot glue melted and disfigured the plastic. But my glue gun is a high-heat glue gun. I figured I'd eventually buy a low-heat glue gun and try again. Maybe we'll test the high-heat glue gun with the duct tape to see if that will protect the plastic. Thanks for a simple and straightforward Instructable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:qwertyboy(qwertyboy's Projects)
I'm just a cool guy making cool things and doing cool stuff.
