We use the side deployment technique because we often have a camera and altimeter mounted in the nosecone. Having them rigidly attached to the rocket body gives them a more stable platform on the way down.
There are a lot of different ways to achieve side deployment as well. We like to construct ours so that the outer aero-shell is separate from the actual mechanism itself. This makes construction and adjustment much easier. It also allows the mechanism to be easily reused if the aero-shell becomes damaged.
The procedure below outlines the general steps of how we construct ours. No specific dimensions are given here as these will depend on the bottles you use and how much space you want to allocate for the parachute.
Materials
- Corriflute (Coroplast, Twinplast, Correx ) corrugated plastic sheet
- 2 PET bottles
- Cardboard
- 2 rubber bands
- Paper clip
- String
- Wire
- Skewer stick
- Ping pong ball
- Timer (Tomy timer, flight computer etc.)
Tools
- Tape
- Contact glue
- Scissors
- Craft knife
- Long nose pliers
More water rocket instructions such as these can be found at our main website:
www.AirCommandRockets.com
Remove these ads by
Signing UpStep 1
hobbking servo
It also has drop away boosters but the are different to yours....
If you would like to check it it please go to http://www.instructables.com/id/Professional-water-rocket-guide/ or it apears to be in the realeted at the bottom of this page
There is no "Instructable" but we have instructions on our website on how to make the different components for this rocket and then you can assemble them into one that looks like this.
Here:
http://home.people.net.au/~aircommand/construction.htm
and here:
http://home.people.net.au/~aircommand/construction_2.htm
Yes, we have done tests with fiberglass strapping tape, and you are right it is great stuff and does a good job of reinforcing bottles and FTC tubing.
We have not made a boost glider yet (too many other projects :) ) but there have been plenty of people who have. They have made them remote control and have put cameras on them.
If you are interested, in the water rocket recovery guide:
http://home.people.net.au/~aircommand/recovery_guide.htm
you will find some examples of boost gliders people have made for water rockets. Scroll down to the Glider/Wings section.
There are some links to good YouTube videos of onboard footage from the gliders.
Cheers
- George
You're welcome ;-)
