3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Watercooling a laptop on the cheap
Step 12Fix leaks and reassemble system
Fix all the leaks and put everything back together.
Keep the cooling system running with no leaks for at least 24 hours before powering up.
Be prepared to troubleshoot odd problems.
My reservoir kept leaking, I discovered that it was building up lots of air pressure inside and blowing out the glue seal. I installed a needle valve from a lawnmower carburetor, that seemed to fix it.
If any one has other solutions, let me know.
2 comments
Mar 22, 2011. 9:10 PMMatrix-technician says:
You could install a low pressure check valve. works like a carburetor neddle.
Jul 16, 2009. 8:21 AMwscottc60 says:
I was thinking about using an expanding balder for a reservoir capture tank. Something like a piece of innertube, might could even use the valve stem in as much as it is threaded.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jack ruby
I'm Just this guy, you know.
