Step 3Get other stuff
I used 3/16 ID vinyl tubing from the hardware store, it is strong yet flexible it has an OD of 5/16
More tubing:
I used 5/16 ID for this, if you can't see where I'm going with that...
A pump
I got one from ebay $20 shipped with power supply. If I were to do it again... I'd get a proper water cooling pump.
Radiator
I'm using an add-on transmission cooler from O'reilly auto parts. It comes with mounting hardware and looks pretty nice. It should have the thermal capacity of 800 of the laptop's built in heat sinks.
Fans
Whatever. I'm using two thermaltake fans wired in series with a temperature controller. One fan is a smartcool the other is a thuderblade. Both together were $29 shipped from newegg. If I were doing this over, I'd skimp on fans and splurge on pump.
Reservoir
A gerbil water bottle from petsmart. It has a detachable clip on the back and 3/16 tube fits right in the hole where the metal drinking tube went.
Power supply.
I'm using a 13.5 v psu for the fans and a 12v psu for the pump (the one that came with it)
Try that one.
Lol if you get one from Harbor Freight, be sure to buy at least 5, you'll need to keep replacing them. ;)
Bought a Sawz-all from them once... lasted a good 3 minutes. But now I have an awesome 110v speed controlled motor to do something fun with, so no complaints :D
