3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Watercooling a laptop on the cheap
Step 9Mount other stuff
Now that the radiator is mounted you have to attach your pump and reservoir.
Of course, you already spent all your time agonizing of the mounting and routing locations (didn't you?) so this part just means attaching the hoses and sticking everything down with heavy duty (outdoor strength) double stick tape.
Now, a word on attaching an routing tubes:
At first I was using small plastic elbow bends to make sharp corners with my tubing, but those limited flow too much. So I went with the method used here: http://folk.ntnu.no/bardlund/hack.jsp
Bard told me to heat the tubing gently and bend it and stretch it.
I heated using my gas stove.
I bent the 5/16 tubing by placing a thick copper wire inside, and holding it near the flame to GENTLY heat it. I then held the section of tubing in cool water for 1-2 minutes so it cooled fully. Then I removed it and attached it to whatever. This way I could make elbow bends that fit over the 5/16 inlets and outlets of the pump and rad. They don't reduce flow and they look pretty nice. The other advantage is you can just shove the smaller tubing right inside for a water tight fit. If you're nervous, just use some glue.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jack ruby
I'm Just this guy, you know.
