Watermelon Chervil French Macarons
Introduction: Watermelon Chervil French Macarons
Ferrous Chef: Watermelon
Third Prize in the
Ready for a challenge?
Step 1: Ingredients
you will need:
100 g ( 2/3 cup) ground almonds
180 g (1 1/2 cups) powdered sugar
2x 5 tablespoons fine sugar
3 eggs ( White + yolk)
1 handfull chopped chervil
food coloring ( green and red)
100 g ( 2/3 cup ) watermelon
50 g (1/4 cup) butter
Step 2: Cookies
Preheat the oven to 160º C ( 320 ºF ) and position 2 racks in the lower section of the oven. Line 2 rimmed baking sheets with parchment paper. If you have time, draw 1-inch circles on the back of each sheet, spacing the circles at least 1/2-inch apart.If your almond meal is very coarse, grind it with the powdered sugar in a food processor until fine. Sift the almond meal-powdered sugar mixture twice through a mesh sieve. Add the green food coloring and the chervil. Place egg whites in the bowl of a stand mixer (or use a hand mixer like i do), and begin to beat on medium-high. When the eggs are frothy, gradually add granulated sugar 1 tablespoon at a time until fully incorporated. Continue to beat the egg white mixture until glossy and stiff peaks form when you lift the beaters. Be careful to not overbeat the meringue (e.g., the meringue takes on a clumpy texture).Add half of the sifted almond mixture, and gently fold it into the meringue using a flexible silicone spatula. Lift from the bottom, up around the sides, and toward the middle, being careful to not overagitate the meringue and lose too much air. Once the almond mixture is predominantly incorporated, add the second half and repeat the folding motion.When the almond mixture is just incorporated, you will need to transform the batter into the appropriate texture. Using the flat of the spatula, "punch" down into the center of the batter, then scrape more batter from the sides to the center, and punch again. You will need to repeat this 10-15 times (or more, depending on your arm strength and the beginning texture of your batter) until the batter slowly and continuously drips back into the bowl when you scoop it up with the spatula. Think of the consistency of molten lava. For the best results, punch the batter a few times, check the consistency, then punch a few more times, etc. Do not make the batter too runny or the macarons won't rise as they should.Pour batter into a pastry bag fitted with a 0.4-inch tip. In a pinch, you can also use a gallon-size Ziploc bag: just snip a teeny bit from one of the bottom corners. Twist and clip the top of the bag to avoid overflow. On your prepared baking sheets (or silicon macaron sheets) pipe out 1-inch rounds in the circles you drew (remember to draw the circles on the back side of your parchment to avoid ink or pencil stains on your macarons!).Holding the baking sheet in both hands, rap each baking sheet firmly on the counter two or three times. This smooths out the tops and helps form the "pied" or frilly foot on the bottoms of the macarons. Allow the piped macarons to dry, uncovered, for at least 15 minutes. The macarons should form a very thin, smooth crust where, if you tap it lightly with your finger, the batter will not stick to your finger. If after 15 minutes, the batter is still sticky, let it dry longer. This may take up to an hour on humid days.Place both baking sheets in the oven and bake for 12 minutes. After the first 2 minutes, open the oven to allow any excess humidity to escape. Halfway through, swap oven racks and rotate the sheets for even baking. The macarons are done when they are baked all the way through and the shells are just hard. Take care to not underbake (insides will still be mushy) or overbake (tops will begin to brown). Remove them from the oven, and cool on baking sheet placed on a wire rack.When fully cooled, assemble the macarons with your choice of filling. The assembled macarons can be stored in an airtight container in the refrigerator for up to one week.
Step 3: Make the Filling
Crush the watermelon finely. Strain everything into a heatproof bowl. Heat au bain marie. Add the sugar, egg yolks and butter. Mix and allow to warm to a cream is created. Add some red food coloring if you want. Putt it to rest in the refrigerator for up to two hours.
Step 4: Combine
 Pipe or spread onto one macaron half and sandwich between the other. Taste! first you taste the sweetness of your watermelon filling and then a soft touch of chervil takes over. Keep them in a box in a refrigerator. .. the day after they tastes the best.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    Very nice! I like your creative use of the contest ingredients. Good luck!
    Awesome! They look so beautiful. Great idea. Hope you win. Voted!
    Lovey and super impressive! I especially like the watermelon curd idea. Does it keep a nice bright flavour when its heated?
    i didn't know what to expect... but i was surprised by the fresh taste of watermelon! the taste didn't get lost by heating.
    Probably the most colorful cookie I've ever seen! Very interesting recipe, I have to say. Glad you share this, thank you!
    How creative! It looks like it tastes great too :)
