Introduction: [Waterproof DS18B20 Sensor Kit Tutorial_1] DIY: Auto AC for Your Pet Fish
About: a maker
The sweat came out in a fine dew on my forehead when I left a room with AC and get outdoor yesterday. It just came up to my mind that my pet fish may need their own auto AC since I would go for a trip some day. So I DIY an AC through Waterproof DS18B20 Digital Temperature Sensor from DFrobot. It suits every rectangular fishbowl and costs little power.
Step 1: Deal With All the Hardware Connection(NO SOLDERING REQUIRED)
Step 2: Install Arduino IDE
Open the next URL and pick the correct version for your machine. https://www.arduino.cc/en/Main/Software
Step 3: Upload the Code &Add Library Through This Button.
#include
int DS18S20_Pin = 2; //DS18S20 Signal pin on digital 2
int E1 = 5;
int M1 = 4;
int E2 = 6;
int M2 = 7;
//Temperature chip i/o
OneWire ds(DS18S20_Pin); // on digital pin 2
void setup(void) {
Serial.begin(9600);
pinMode(4, OUTPUT);
pinMode(7, OUTPUT);
void loop(void) {
int value =0;
float temperature= getTemp();
Serial.println(temperature);
delay(100);
if(temperature > 25.00)
digitalWrite(M1,HIGH);
digitalWrite(M2, HIGH);
analogWrite(E1, 255); //PWM
analogWrite(E2, 255); //PWM
delay(30);
else{
digitalWrite(M1,LOW);
digitalWrite(M2, LOW);
analogWrite(E1, 0); //PWM
analogWrite(E2, 0); //PWM
delay(30);
//just here to slow down the output so it is easier to read
float getTemp(){
//returns the temperature from one DS18S20 in DEG Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
ds.reset_search();
return -1000;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return -1000;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print("Device is not recognized");
return -1000;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float tempRead = ((MSB << 8) | LSB); //using two's compliment
float TemperatureSum = tempRead / 16;
return TemperatureSum;
Step 4: Decorate Your Project and Make It Suitable for the Size of the Fishbowl
Step 5: Check Everything Yourself!!!
Leave your pet fish a ‘coolest’ summer ever.
