3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Waterproof Pocket Sized Battery Storage
Things that use batteries seem to be in need of fresh cells every time we turn around.
Simple solution, carry extra batteries in your pocket, or a specially designed carrier.
Unfortunately, there are problems with both of these methods.
If you carry batteries loose in your pocket, you run the risk of loose change or other pocket items accidentally discharging them, some times violently.
Both Surefire and Batuca make fantastic spare battery carriers. Both of them are great and perfect for carrying in or on your pack (see County Comm, T.A.D. Gear, or Maxpedition for outstanding belt mounted/PALS mounted pouches for the Batuca cases.) However, these carriers are a bit to bulky for every day pocket carry.
What follows is a solution I developed after being inspired by Tommi Potx and his instructable Several of 1000 Uses for Old Bicycle Tubes. Much thanks to him.
Because of the low cost and short assembly time, these are meant to be disposable.
Cost: <$5 (excluding batteries)
Assembly time: <5 minutes.
Step 1Stuff Needed
Stuff Needed
Here is what you'll need.
1. Batteries.
For this instructable we'll be using 2 Surefire lithium SF123A 3 volt cells. It is also easy to do this with 1 AA, 2 AA, 4 AA, 2 AAA, 4 AAA, or any other combination of cells. Only use the same type of cells, don't mix AA's and 123's) Also, don't mix old and new cells.
2. A length of bicycle inner tube.
The length, diameter, and type of type of tube used is dependent on the size and number of batteries being enclosed. For the SF123A's well be using 4" (10cm) of road tube. If you're packing the cells end to end you want the tube to be long enough to cover the cells with about 3/4" (2cm) of tube stick off on either end (see picture 2). AA, and 123A's can be packed end-to-end comfortably in road tubing. AAA fit into road tubing side-by-side quite nicely. You can also fit 4 AA side-by-side in mountain tubes (see picture 3)
Tubes can be found new at bike shops for under 5 dollar, and can be found free in the dumpsters behind said shops. It doesn't matter if they have holes in them or not, you'll be cutting them up.
Make sure you are using tubes that do not (nor have ever had) any kind of sealant in them (Slime, Stan's...) They need to be clean and dry on the inside.
3. 2 Zip ties.
The small thin ones work quite well in this application.
4. A measuring tool.
To measure out the length of tube
5. A cutting tool.
To cut the tubing.
2 comments
Mar 23, 2008. 6:55 AMLinuxH4x0r says:
Awesome! made make
Feb 18, 2008. 8:07 PMGorillazMiko says:
This is definitely a great job, very well done Instructable. I would have never thought of this, because this Instructable is just genius. Great job, will have to do this next time I need to. First I need to get some tubing... +1 rating.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Hodge-Podge
