Waterproof Case for X10 Palmpad or Other Gadgets
Published
Introduction: Waterproof Case for X10 Palmpad or Other Gadgets
This is how I waterproof my X10 palmpads. This works great for the pool, hot tub, shower etc.
You're probably wondering why I want one of these in the shower. There is a lot of stuff you can control while in the shower. Music volume, track, have your house read you the news headlines etc. (I do all of this with Homeseer)
You could easily use this method to make a waterproof or sand / dirt proof bag for any occasion. It's inexpensive enough you can make a bunch.
It also floats!
Step 1: Cut Plastic Down to Size.
This plastic is the kind you would usually use to cover a table. I purchased it at Walmart, it's very inexpensive. They make it in a couple different thicknesses, I think the thinner stuff works just fine.
I used 8" x 8" squares to start for this bag, you could get away with 8"x7" for the X10 palmpad, but it makes the last part a little harder.
You can adjust the size depending on what gadget you are trying to seal up.
Step 2: Seal the Edges.
Fold this sheet in half, and seal the edges using a Foodsaver, us the manual function since you won't be using the vacuum part of the Foodsaver.
In order to seal the plastic properly, I use the manual function 3 times, and then I flip the plastic over and seal it 3 more times, on the other side for a total of 6 times. Press firmly down on the Foodsaver while sealing.
You might be able to get away with 1 or two on each side, but I'm in no hurry, and 3 has seems to be very strong for me.
You MUST press down on the Foodsaver near the edge while sealing, this is an important step that's needed to get a good seal since the plastic is much thicker than a Foodsaver bag.
Step 3: Seal One End.
Again press down firmly on the Foodsaver, seal it 3 times in manual mode, then flip it over and seal the other side 3 times.
Step 4: Last Minute Tweaking of Your Gadget.
Don't forget to set the house code, install fresh batteries and test the palmpad. You won't be able to do any of this without destroying the bag after the next step.
Step 5: Insert Palmpad and Seal It Up.
Insert the palmpad or gadget, and seal it up.
Again, 3 times each side, don't forget to press firmly on the foodsaver as can be seen here with my thumb.
Step 6: Trim Up the Edges and You're Done!
I cut the edges to be rounded a little bit, and trim off the excess plastic.
You're done!
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    9 Comments
    how would i do this without a foodsaver? maby an iron please help
    I think that a soldering iron would be easiest to control where you want it to melt. You can get an 8-piece soldering kit at radioshack for about $10
    You could try an iron, I'd make sure some paper was between the plastic, and the iron. as well as the plastic and your ironing board.  I haven't tried this, so be careful and use good judgment about how to apply the heat with the iron, obviously melting plastic could be dangerous if you heat it too much.
    Let us know how it turns out.
    awesome. I think a lot in the shower, so I've recently taken to bringing my ipod touch into the shower so I can write stuff down. I'll have to try this. :)
    I've put my touchscreen phone in one before, it seems to work okay through the plastic. If you are going to be taking it out of the plastic often they make little bags designed for cellphones and such just for the purpose of keeping it waterproof for the boat / beach / "shower"
    I found some at a store near me for $10ish @ Meijer. For these touch pads I'm using, you might have to change the batteries every few years, where as a phone or ipod it would probably be much more often.
    something similar to this http://www.bhphotovideo.com/bnh/controller/home?A=RetrieveSku&IC=AQMIPC&Q=&O=
    I just took your idea and made a dry bag for boating. Very useful! Thanks!
    You are most welcome, I hope it was helpful.
