Waterproof Speakers
25,092
40
13
Posted
Introduction: Waterproof Speakers
Hy!
In this instructable i will show you how to make mini waterproof speakers that you can use everywhere
Step 1: You Will Need
Hot glue or Epoxy
Soldering iron
Marker
Scissors
Waterproof container
Speakers and amplifier
Screwdriver
Sanding paper
Step 2: Remove Speakers
Remove speakers and amplifier from speaker housing
Step 3: Desoldering
Desolder speakers
You will need only right speaker
Step 4: Cut the Lid
Mark it and then cut the lid and sand it so it will perfectly fit on speaker
Step 5: Mixing Epoxy
Now mix epoxy and glue the speaker on lid
You can do this with hot glue but i prefer epoxy
Step 6: Put Speakers in Container
Drill hole for the power and audio cable
Put amplifier inside
Now solder speaker to right channel
Step 7: Test It
Now test it
If its everything ok then put some hot glue into hole to isolate it
Step 8: You Are Done!
Now just close it and you have waterproof speaker :D
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    12 Comments
    All speakers can handle water to some point, i should probably edit this instructable, using standard speakers will make it splash resistant not completely waterproof, if you want to make it waterproof get something with plastic cone and rubber surround
    Great idea. I'm using a smaller version of this to build into the straps of my back pack. :D
    that amp is from speakers yes? because it sound pretty good! A link for the speakers maybe?
    it was from some no name speakers
    is there any info on it? serial number or something like that?
    it uses TDA2822 IC in stereo configuration and its powered with 4xaaa (6V input)
    You can make your own TDA2822 amp in bridged configuration (if you have one speaker) and it will give 2-3W at 4Ohms (in stereo 1W/channel at 4Ohm)
    were those speakers like these?
    thanks for info! by the way good intructable!
    I've got to ask - have you tested these wet?
    And what do you mean by "waterproof"? Are they shower-proof? Submersible?
