so, for a while now i've been waterproofing my batteries. its incredibly easy! so easy in fact that i really wonder why some of the manufacturers don't do it already.
This project is brought to you by MonkeyLectric and the Monkey Light bike light (which now includes a 100% waterproof battery holder so this tip isn't needed)
Step 1: What you need
Step 2: Do it!
ideally you want a waterproofer that starts as a thin liquid so that it soaks in well - there is a fiber washer around the metal dimple, which should soak up your waterproofer, and it will also soak into all the corners under the washer.
that's it! .... unless your battery is already well used? the 2nd photo below is a battery that had already suffered quite a bit of wear and tear - the plastic wrap was partly ripped, and the fiber washer was damaged so i removed it. in this case its still very easy - just put a few drops into the dimple area, and use something thin like a paper clip to spread it all around into the gaps.
if you accidentally get some on the dimple, you can wipe it off before it dries, or scrape off afterwards.
Step 3: How it works
The entire can of the battery is made from stainless steel - totally rust-proof. so why does it rust? its because right around the dimple area is where the positive and negative of the battery meet at their closest point - and when water gets into this area, it allows electrolytic corrosion to occur - the electricity from the battery flows through the water, and this causes corrosion of our otherwise impervious stainless steel (as well as rapidly discharging the battery!)
So - all we need to do to make the battery impervious is to apply our waterproof coating around the dimple area, covering the area where the positive and negative are near each other.
Check out the photos below, where i've peeled away the plastic wrapper at the top of a battery to show this in detail. the bottom (negative) end of the battery actually extends under the label and up the sides of the battery all the way to the top - where it is separated from the positive (dimple) end only by a thin rubber seal. its very easy for water to get in the groove next to the seal and create a conductive path from positive to negative. the battery also is made with a fiber washer around the dimple - this protects this area from getting damaged (without it it would be too easy to short out the battery by dropping a screw next to the dimple) - but the standard fiber washer that is used soaks up water quite well, providing lots of nice water to corrode the battery.
in the 2nd photo i show the safety-pressure valve. if you accidentally over-charge your battery this valve will open to prevent the battery from exploding. if you are using a fairly thin or flexible waterproofing material the valve should not have a problem still working, but you probably don't want to use epoxy or any really thick or strong material as it will block the pressure valve from working in the rare case that it needs to.
Visit Our Store »
Go Pro Today »
First heard about the charger on this site which reviews batteries and chargers:
http://www.users.on.net/~mhains/Bestbuys.html
Here's another couple of links - one is the manufacturer's page:
http://users.tpg.com.au/users/p8king/rezap.htm
http://www.rezap.com/
VERY good point. rechargeable batteries have a small vent in case the battery overheats. If that vent is covered then the battery can explode.
overheated battery = explode
Gas generates not as part of the desired electrochemical reaction but as a function of side reactions. While the vents are not critical to a single cycle, over time gas pockets over the electrode will limit current flow and increase the impedance of the cell. As impedance increases, the heat generated during use increases, generating more gas and, without vents, may end up covering more of the electrode, further increasing impedance and heat generation, and there we get a vicious cycle. At best this decreases the cycle life of the cell, at worst they "pop" coating any neighboring electronics with basic solution.
That said, one must balance the degradation caused by external influence through the vents against the purpose of the vents. Since most battery applications are in "dry" environments, the vents are generally a good thing, but in marine or high humidity environments partial sealing does improve cycle and discharge life.
Lithium and Lithium-ion cells have no vents because, while there are side reactions, O2 and H2O contamination is both irreversibly harmful to the battery (permanently oxidizing any active lithium in the carbon anode) and to people (water + active lithium = boom). Alkaline cells work because of O2 and H2O, so the vents don't intrinsically harm the cell.
