3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Waterproof your Batteries in seconds!
If you do a lot of outdoor work or play in foul weather, you've probably noticed that keeping your batteries dry can be a bit of a hassle - they are metal so they attract condensation. And you've probably also noticed the considerable importance of keeping them dry. Not only will a wet battery rust rapidly, the water can create a conductive path around the top of the battery which rapidly discharges it - leading to a nasty surprise if you are counting on your gps or flashlight! I've also discovered that even if i keep my spares in a ziploc bag, some of my "waterproof" electronics (like my gps) are actually waterproof on the inside, but not the battery compartment - so while the gps electronics are happy and dry, the batteries powering it are sitting out in the damp cold still!
so, for a while now i've been waterproofing my batteries. its incredibly easy! so easy in fact that i really wonder why some of the manufacturers don't do it already.
This project is brought to you by MonkeyLectric and the Monkey Light bike light (which now includes a 100% waterproof battery holder so this tip isn't needed)
Step 1What you need
All you need is a waterproof coating material. There are a wide variety of products which work well: at your home improvement store there are lots of options such as urethane waterproof coatings, rubberized paints, etc. from an electronics supply story you can find silicone and urethane conformal coatings which also work very well. these coatings soak in well, stick to metal, and dry to a rubbery finish. if you are in pinch, you can do quite well just using standard oil-based paint, or nailpolish. these soak in and stick well, but are a bit hard when they dry so i suspect they may chip off over time (although i have not tried them enough to say for sure).
34 comments
May 14, 2011. 9:52 AMducktape.mac says:
would petroleum jelly work?
Aug 13, 2009. 1:09 PMlusoc says:
Perhaps you could use Tyvek as a coating. It prevents liquid water but allows air flow (and thus calms some of the "OMG VENTS" worrying). It does allow water vapor through so I suppose high humidity could still be damaging. Also I'm not sure how well it melts down for coating.
Dec 13, 2007. 1:19 PMwinston_smith says:
You kids are way to paranoid about the "vents". No one has pointed out that if you have corrosion on the top of the battery, the venting won't work anyway because they'll get stuck.. It takes a lot more to make them vent then the average charger is likely to do.. I've seen it done, and a) you'll know and b) you're unlikely to use them afterward anyway.
Jun 16, 2008. 9:06 AMceltic58 says:
Everyone should be aware that alkaline batteries produce hydrogen gas under 2 conditions: 1. normal oxidation that occurs all the time whether the battery is being used or not. 2. over discharge. Duracell and Energizer both have guidelines that ask the batteries be in vented compartments, or have materials in the compartments that absorb the hydrogen gas, i.e., "polypropylene, polyethylene, or some other gas permeable material should be considered." You should not take the handling of these devices lightly. Bad things have been known to happen when misused.
Dec 13, 2007. 5:09 PMwinston_smith says:
This does a pretty good show of what happens... note the "crater" and "smell" comments... the smell is really bad..... but when they're charged wrong, you typically know because they get REALLY hot... like melting their way out of a plastic case hot.
Dec 10, 2007. 12:17 PMHoopajoo says:
Alternatively, you could use automotive dielectric grease. It's used to keep automotive and marine bulbs and contacts from corroding in moist environments. I used it on the batteries in my solar pathway lights as they were always corroding and oxidizing from the rain. Worked quite well ans is reasonably cheap. Just remember, a little goes a long way.
Mar 19, 2008. 6:57 PMSpokehedz says:
Vasoline will work in a pinch.
Jan 30, 2008. 9:28 AMjackever says:
I would suggest using a plastic paper clip, wooden or plastic toothpick or other non conductive tool as a metal paper clip could short the battery momentarily if the plastic insulator is damage or you poke the clip under it.... Overall a very good Instructable
Dec 11, 2007. 2:52 PMOutlander says:
This is dangerous! Alkaline batteries vent hydrogen when in use or being charged, sealing the batteries can cause them to bubble and burst! Not advised.
Dec 18, 2007. 4:39 PMOutlander says:
The tops of the battery are the vents, and if you go to Duracell's website, under AA usage(pdf file download), it states that alkaline AA batteries need general ventilation for normal use. Notice how the batteries always seep out the top vents, or come out the bottom as they age also? Normal alkalines are not "supposed" to be recharged, but the rechargeable alkalines are basicly the same thing and I have used AA batteris after 25 recharges with no problems except they dont last long and after about the 25th time(if that, some work once or twice) they dont hold a charge anymore. not trying to insult this instructable at all, but it needs a stupid people warning, ie. "warning this can cause batteries to burst", or "do not store once sealed" etc. Good job anyway.
Dec 12, 2007. 7:02 PMMadMechanicMike says:
actually they do have vents.
Dec 11, 2007. 7:35 PMvictor9000 says:
Actually there are some chargers (one made in Australia, in particular) that seem to do a good job recharging alkalines. It will recharge most brands except for Duracell - they tend to leak in that particular charger. You won't get as many cycles as a secondary battery but its good for about 10 - 15 charges. So far it seems to work on the AAAs and AAs I've put in it.
Dec 13, 2007. 4:42 PMsehrgut says:
Ummm . . . you're thinking of "rechargeable alkalines". Ordinary alkalines are still one-shot -- rechargeable alkalines give you a dozen or so cycles (much more if fastidiously managed).
Dec 13, 2007. 5:03 PMwinston_smith says:
There were a couple mfr's who made chargers for standard alkaline's... But they never really caught on in Canada or the US... too many people growing up being told not to charge them lest they explode to overcome. That said, NiMh batteries are close enough to alkalines these days in both capacity and cost... *shrug*
Dec 13, 2007. 7:06 PMvictor9000 says:
Just finished recharging some AAA Energizers and a Panasonic Digital (from a set that was included with my TV remote). None of these are marked rechargeable alkalines. Best I can tell, they are "standard" alkalines. Also charged a bunch of Red Cell AAAs (bought at CompUSA - made in Germany). Also charged an Energizer Titanium. Best I can tell, these are all standard primary cells. I'm using a ReZap charger (made in Australia) and it seems to be doing the job well enough. I personally like to use the ultra low discharge NiMH cells such as Eneloop or Hybrio as they keep the charge for quite a while. My wife continues to buy alkalines and I hate to throw them out after one go round. After getting rid of the "duds," I've got about 40 cells which are now being recycled rather than heading for the landfill. I figure I'd rather "use them up" rather than use once and throw away. I saved alkalines for six months before buying this charger. I had about 60 batteries - mostly AA and AAA. I still have a bunch of Duracells in a bin which will supposedly leak in my charger. Haven't wanted to try them yet.
First heard about the charger on this site which reviews batteries and chargers:
http://www.users.on.net/~mhains/Bestbuys.html
Here's another couple of links - one is the manufacturer's page:
http://users.tpg.com.au/users/p8king/rezap.htm
http://www.rezap.com/
Dec 14, 2007. 3:08 PMleef_me says:
>>are actually waterproof on the inside, but not the battery compartment - That's not waterproof, that's splash or water 'resistant'. I had cause to take some D cells apart and found in my case that the "closest point" was actually on the negative end of the cell. When the outer plastic jacket was removed, I found the dimple was in a disc that touched the outer case of the cell. I confirmed this on Ever.. and Dura.. brands. I had D,C and AA to check.
Dec 14, 2007. 4:50 PMshop dweller says:
Great idea! Petroleum jelly works well on outdoor battery terminals as well, but use a super light coat (unless you want a big, gooey mess in your battery compartment). I know it's kind of off the subject but I use it in all my flashlights. It reduces thread galling and keeps the seals from getting nicked as you're replacing the the caps. I put a light coat on the spring inside to reduce oxidation and I can honestly say that I have never had to replace a spring in any of my Mag lights -the oldest one I have is pushing 20 years or better.
Dec 13, 2007. 6:13 PMStarBlades says:
"You kids are way to paranoid about the "vents". No one has pointed out that if you have corrosion on the top of the battery, the venting won't work anyway because they'll get stuck.. It takes a lot more to make them vent then the average charger is likely to do.. I've seen it done, and a) you'll know and b) you're unlikely to use them afterward anyway. "
VERY good point. rechargeable batteries have a small vent in case the battery overheats. If that vent is covered then the battery can explode.
overheated battery = explode
Dec 10, 2007. 12:30 AMOra says:
Nice easy fix! Thanks for the fact about the negative terminal going along most of the battery. I think I might hook some up like 9 volt batteries with both terminals at one end. It would make wiring them in a series or in parallel much easier.
Dec 10, 2007. 11:32 PMgijzo says:
How about candlewax?
Dec 10, 2007. 4:18 PMGorillazMiko says:
wow, smart! i might do this.
Dec 10, 2007. 7:25 AMalceste says:
Nifty idea, but you have to be careful if you're going to seal those vents: they're put in place to allow vapor to escape as gas builds during use: be sure to put them in a mechanically tough enclosure.
Dec 10, 2007. 2:35 PMalceste says:
The vents are there for a reason.
Gas generates not as part of the desired electrochemical reaction but as a function of side reactions. While the vents are not critical to a single cycle, over time gas pockets over the electrode will limit current flow and increase the impedance of the cell. As impedance increases, the heat generated during use increases, generating more gas and, without vents, may end up covering more of the electrode, further increasing impedance and heat generation, and there we get a vicious cycle. At best this decreases the cycle life of the cell, at worst they "pop" coating any neighboring electronics with basic solution.
That said, one must balance the degradation caused by external influence through the vents against the purpose of the vents. Since most battery applications are in "dry" environments, the vents are generally a good thing, but in marine or high humidity environments partial sealing does improve cycle and discharge life.
Lithium and Lithium-ion cells have no vents because, while there are side reactions, O2 and H2O contamination is both irreversibly harmful to the battery (permanently oxidizing any active lithium in the carbon anode) and to people (water + active lithium = boom). Alkaline cells work because of O2 and H2O, so the vents don't intrinsically harm the cell.
Dec 10, 2007. 3:08 PMalceste says:
lithium sulfur cells have "one way valves" in case of an internal short. In any case you've intrigued me. I'm gonna take a couple of ni-mh cells and see how a sealed cell functions against a vented cell.
Dec 10, 2007. 12:25 PMmrbob1000 says:
theres no gas vents now... this means your batteries are now much more likely to have a failure.
Dec 10, 2007. 12:33 PM!Andrew_Modder! says:
good idea :-). but you actually covered the gas holes, so when you charge you battery and it gets to hot, it will probably explode!! or if it shorts out, or gets to hot. so really this isnt good to do, but good idea ;-)
Dec 10, 2007. 10:58 AMJames (pseudo-geek) says:
man thats brilliant. I'm going to do this on my rechargeables.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
526
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
