The shape that you see in the images below is the result. I'm pretty happy with it; it's really pleasing to the eye, and is a very stable platform for my Macbook (though it should work for most laptops 12" or wider.)
The third picture on this step is my old laptop stand, which will give you an idea of why I wanted to make a nicer one (yes, it's a piece of plywood on four coffee tins.) The new stand has a number of benefits. It:
- Raises the screen up higher, closer to an ideal height for my eyes (and putting the webcam at a more natural angle.)
- Tilts the body down, for easier touchpad and keyboard use, for the occasional times when I type on the laptop in its stand.
- Makes the desk feel less cluttered.
- Mirrors the form of my ergonomic keyboard.
Step 1: Brainstorming and Initial Design
The first step was to break out a pencil and start sketching. I played with a couple of ideas before settling on the one at the bottom of the page. The basic idea was a distorted plane, with three points touching the desk surface and three points hitting the bottom of the laptop. The side view (on the right) shows how the whole thing should be squeezed to angle the laptop.
Step 2: Transferring to the Computer
- Design the 3D shape of the object.
- Figure out how to create slices through the object.
- Programmatically cut out interlocking slots for each intersection of the slices.
- Export the resulting shapes as 2D outlines.
Anyway, back to this design method. I decided to design from the side view, first. The image below shows the cross sections that I came up with. You can see the gray trapezoid around the whole thing, showing a flat bottom and an angled top for where the laptop would rest. Within that, I drew two shapes. The fat one is the plane through the center of the stand, running front-to-back. The thinner shape is the shape of stand along the left and right edges. Let's call these the "spines" of the stand.
I added vertical lines for where I was going to want all the cross-sectional slices (the ones that will run left to right.) Each of these lines would then be used as guides to make the actual cross sections.
Step 3: Extrapolating from the Basic Shapes
A couple examples are below. I started by drawing a vertical grid, once again. This spacing was to make things wide enough for my laptop (going from center to right edge) with additional guides for later use. For each vertical slice along the spine, I transferred points to this grid. Transferring points is easy: I copied parts of the shape, dragged them directly over the new grid, and marked points.
The first example below is the front-most piece. I took the left-most line from the spines and measured out the middle spine on the left side and then the edge spine on the right. Then, I played with the bezier handles until I had a curve I liked and that could be copied across the rest of the shapes. In this case, I was simply drawing out the handles to be two guides inwards, each.
The second image below is the second cross-section; I just repeated the process for all the measurements on the second spine cross section.
After a bit of work, I had all nine cross-sections mapped out. I now decided that I wanted two more spines, to go in between the center and the edge spines. To do this, I found the height of each cross section between these spines and transferred them to a new spine (side) shape. You can see it in the third image.
Step 4: Adding Slots
Okay, once I knew what kind of slots I was using, I made some little slot templates to make adding them to the spines and cross-sections easier. The idea was to measure the place where the slots met using the top-most curve of each shape. You can click through the two series of images, below to see how it was done. The image notes have all the details.
saddle laptop stand2.ai(612x792) 1020 KBStep 5: Layout
I them laid out the pieces according to the size of the sheets of plywood that I had on hand. I'm not going to pretend that this is some sort of optimal arrangement; I fiddled until they fit, barely, and called it done.
On this step, you can find the vector files for these shapes in several different file formats. If you just want to download this and get to work cutting it out, one of these should do the trick.
saddle laptop stand - layout.eps(1729x1703) 331 KB
saddle laptop stand - layout.pdf(2160x2160) 249 KB
saddle laptop stand - layout.ai(2160x2160) 1 MBStep 6: Laser Cutting
Step 7: Assembly
After about 30 minutes, it was done! You can see the completed stand in the pictures below.
Step 8: Admire your Work, Think of Improvements
Improvements, for the future:
- Design it in 3D! See step 2 for my thinking on this. If you have suggestions, please leave them in the comments.
- The slots should be looser; glue can be used instead of friction to keep everything together. "Nodes" can also be used for a nicer fit. See step 4 for details on this.
- Though the stand is very strong and stable, there is just a bit of flex on the rear legs. I'd eliminate that with a thicker shape that keeps that last cross section a bit fatter in the middle.
Visit Our Store »
Go Pro Today »
Very nice! I would have to build one!
Without a laser cutter, you could try foamcore (which will still be quite weak) or using traditional woodworking tools like a scroll saw to cut wood.
Thanks for sharing, and how fortunate you are indeed to work at Instructables~ I am envious....heh heh...but maybe when I move to the Bay area I'll apply....
In any case, I moved on from Instructables a long time ago, but still remember my years there fondly. And I still use this stand every day :)
Thanks for this, leugim.
DI Sara (UBA) ;)
El T-Splines te permite hacer la forma que vos quieras al ala, el Rhino solo es duro para lo organico.
Sara.
Great design!!!
Sorry to say this, but i am in disbelief that this is generating as much feedback as it is. check out the work over at www.grasshopper3d.com
this kind of stand can be made by any architecture student in there sleep if they are familiar with rhino and grasshopper. not faulting you, but you have crossed into a realm of parametric modelling where this would not be taken seriously seeing as how it was created with anything adobe. In a scripting sense this form would be extremely basic to create. I think you should invest a couple hours into learning grasshopper (free plugin) for rhino (not free, just crack). You can change density of the grid, extrusion distances, attractions, and material thickness with simple sliders.
Aside from that, I do love high tech designs.
I was wondering if it's possible to create a stand that actually conforms to the shape of a human lap, Or even if one can be made that can be used wether your sitting indian style, Or with your legs straight out. Just a thought, cause thats why my laptop sits on my desk all the time.
But I love the design, Because of the overall amount of airflow promoted in this project.
Grasshopper looks pretty easy to use. I code, though, so I'll probably script in Rhino directly when I decide to pick it up. Thanks for the suggestion.
Of course, if you model this or something like it, we'd all welcome some screenshots here or a whole instructable of your own!
It has been fully funded via Kickstarter since May '11, but the software has yet to be released.
I'm really looking forward to it when they do, though, because it looks slick!
pixelpartner says: Nice work! I also spend much time for my design in the SVG app Inkscape. There is a (fresh) free Java application doing exactly your type of work in minutes : http://gregsaul.co.nz/SketchChair/
Thanks! SketchChair looks seriously awesome. I loved the demo video. Let me know when you have Linux/OSX binaries available.
Thanks in advance!
A mesh could help you out, though. The profile it presents to the laser is much narrower, and there's more of it distributed around. Perhaps it would last longer than a few pins.
