3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wave Laptop Stand (Making 3D Shapes in Illustrator)
Step 4Adding Slots
Adding Slots
  • last photo ←
I had to do some tests to figure out how wide to make my slots. Using the same material, I cut out a bunch of rectangles with differently-sized slots and saw how they fit. I settled on slots 0.195" wide for the 3/16" plywood I was using. They were snug, but didn't require a hammer to push together. In retrospect, I should have made them looser, with "nodes" to help the slots bite. You can see an image from Ponoko's manual for this (it's the second one.) That would have allowed easy assembly without too much forcing.
Okay, once I knew what kind of slots I was using, I made some little slot templates to make adding them to the spines and cross-sections easier. The idea was to measure the place where the slots met using the top-most curve of each shape. You can click through the two series of images, below to see how it was done. The image notes have all the details.
saddle laptop stand2.ai(612x792) 1020 KB
4 comments
Apr 1, 2012. 3:45 PMChasingthesun73 says:
Did Pokono's node manual get deleted? I'm curious if / how you can make nodes with a laser?
Dec 14, 2009. 9:15 AMecicnc says:
Are you sure you were using 3/8" plywood? Your 0.195" slot would be very tight for even 1/4" (0.250") material let alone 0.375" material.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
117
Author:nagutron
I'm the former Frontend Engineer for Instructables. Problems with the site? It may have been my fault... Like what you see? Sing my praises!
