3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wavy Cut Paper Bead How-To
  • last photo ←
I love making paper beads for use on my art dolls and for jewelry. I found that zig zag blade on my paper cutter makes beads that look wonderful. The colorful ones are like diminutive mosaics, while the monochrome make me think of snakeskin.
Using glue stick gives a soft, squishy bead, but using a combination of archival paste and glue stick just for the tips gives a solid bead reminiscent of paper mache.
It's addictive - and a fantastic way of using all those junk mail catalogs.
Step 1Cut your
Cut your
Choose a page where the images and color reach the edge of the pages, unless of course you want white beads.
Cut wedges shapes alternating the widest point between the top of the page and the bottom of your sheet. You can cut lengthwise or widthwise - lengthwise gives a slightly fatter bead. I usually make the widest part 1-1.5 inches.
58 comments
1-40 of 58next »
Apr 16, 2012. 7:25 AMsuayres says:
Oh, my goodness! The wavy edge really elevates your beads several levels!
Nov 21, 2011. 10:23 AMquantumpink says:
I had really good luck using mod podge. It is slightly water resistant so soaking it would destroy it but it won't get messed up if water splashes on it when washing your hands.
Oct 27, 2011. 7:01 PMmaikaew says:
So clever and cool!
Sep 12, 2011. 7:25 AMTime4Me says:
Thanks for the wavy cut idea. I've been using just a little school glue (like Elmer's) once I get the rolling started. I usually don't use anything to roll them on because I find it easier to tighten the paper when I can hold the bead between my finger and thumb. After I get a bunch of beads made I stick a toothpick through one end and then into a piece of styrofoam to hold them while I give them a swipe of Modge Podge using a brush. Someone had given me the matte finish, so that's what I've used, but there is also a glossy. The beads harden nicely after they dry, but I still plan to use an acrylic as a last coat to give a little more protection. Someone gave me a couple packages of scrapbooking paper and it makes great beads - nice weight. Also, since many of the packages have a theme or color scheme, it's a good way to make beads that mix and match.
Replyflag[delete]
Jun 2, 2011. 4:10 PMmbranwen says:
Thank you for these instructions. This will be my very first time doing anything like this...it looks fun!!!!
Mar 30, 2011. 10:43 AMMJMATHOT says:
They look great, I will try the wave cutter tonight. I made paperbeads last week with shiny wallpaper, they looked like shells. I used a gluestick only for the end part and painted them with transparant nail varnish, to protect them. In the end the beads didn't look like paper at all. On top of that I started with silverwire, then around the beads and a loop at the end. Is worth trying.
Mar 30, 2011. 8:50 AMkplaisance says:
I recently found a necklace my sister in law made for me back in the late 70's. I was so happy to find it, made from rolled paper beads! Oddly enough, I stumbled on to your instructable just a week later! Guess what I'm doing this weekend! =) Thanks, they are so pretty!
Sep 28, 2010. 12:48 PMcrazyaboutbeads says:
You use a wire to wrap it around?
Sep 19, 2010. 2:56 AMRobin E says:
I keep a small amount of cornstarch in a bowl and just get rid of the stickiness temporarily so I am not dealing with damp or sticky hands. Save the clean-up for later, once I am done for this creative session. Works great.
Apr 11, 2010. 10:12 AMcraftyrn1959 says:
Is yes glue the same as modge podge?
Very nice instructable!
Apr 1, 2010. 8:01 PMSilver Buttons says:
They look so pretty, filling up a basket. =D
Mar 8, 2010. 11:11 AMcocoisa says:
Hola: Me encanto la idea Tengo un monton de catalogos y revistas las voy a
aprovechar. Muchas gracias.
Besos.
Apr 19, 2009. 1:00 PMimaluma says:
Is that Yes paste? I love that stuff! It smells so good!
Mar 8, 2010. 7:00 AMpaperclip32 says:
 Yes,paste.
Mar 7, 2010. 9:12 AMkcls says:
One of the other paper bead 'ible's say to spray glossy varnish on them once the glue dries, to hold them together better. do you recommend this?
Feb 22, 2010. 8:52 AMmahonia says:
Thank you for the simplicity, that is usually a bit more comprehensive.
Aug 8, 2009. 10:09 AMSshebba says:
Very beautiful beads! What is "Archival Paste/Glue" and what type of store do you purchase it from? I've never heard of it before.
Feb 8, 2010. 9:57 AMmuberblob says:
buy it at micheals
Nov 20, 2009. 3:45 PMMaryOfExeter says:
I love making these :) I hadn't thought about making them wavy, thanks!
For mine, I just mod podge as my paste. Once rolled up, I put a coat of it on the ouside of the bead. Then, once that dries, spray with clear acrylic. Makes them durable and the acrylic makes it waterproof :)
Feb 1, 2010. 7:36 PMwildginger13 says:
There is also 'outdoor' Mod Podge. It seals from moisture. We just started  this project in our after-school programs. Silly teens are too busy flirting though. Hopefully we'll get enough done to make some cool necklaces. Thanks.
Nov 20, 2009. 6:23 PMMaryOfExeter says:
Mine seemed to hold up pretty good with the mod podge. I put some pressure on them and they wouldn't budge.
I'll be sure to check out those pictures once Thanksgiving is over with. Sounds neat!
Oct 14, 2009. 9:15 AMrjscheergirl says:
WOW! you're very good at these, i have a younger sister who's only 10and I would like make these with her. Do you think she could handle it?
Oct 11, 2009. 6:57 AMjumpertoad says:
i cant seem to cut correctly
Jul 31, 2009. 12:03 PMANTQNUT says:
Holy smokes! u made ALOT of beads! great instructable!
Apr 9, 2009. 11:02 AM15zhangfra says:
ha, cool, i knew how to make beeds from paper, but never thought of a wavy cut
Sep 5, 2008. 4:32 PMcontainer_gardener says:
I was thinking of using some kind of paper glaze to seal the beads, but Future Floor Wax sound interesting. Does it have an odor?
Feb 4, 2009. 11:15 AMcontainer_gardener says:
No problem...I forgot that I even asked the question!
Feb 4, 2009. 5:00 AMmcshawnboy says:
On DIY Network's "Jewelry Making" with Jackie Guerra she showed a bracelet made of outdated coupons.
1-40 of 58next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:dezignarob
