Step 7: Trouble shooting...
wax isn't perfect and can come across some problems.
'Wax shutdown and said it performed an illegal operation': This means that there was a glitchand it had to shut down. Be careful, there is no solution to this and you will lose all of your work, so save periodicaly.
'Wax won't render. It says that some render engines must have pixels set to a multiple of four.': This can be a problem.I don't know why it happens, it usually, doesn't, but if it does you must redo the project. Try to make these videos in small segments.To avoid the hassle of spending an hour on a faulty file.
'When i open Wax, it says it can't open i\o file, and now i can't import!': Sometimes this will pop up, but you can get around it by closing wax and then re-opening it.
if you have any problems or questions, post a comment. You're welcome to post videos of your creations with wax.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
