Introduction: Wearable Survival Kit (With Tech Additions)
Picture of Wearable Survival Kit (With Tech Additions)
Hello there! Here is an instructable about making a survival kit which can be worn on your wrist! All you are going to need is:
A small plastic box (used here is a TicTac box)
Matchsticks (2)
Part of the ignition strip on the side of the matchbox
BandAid
A Dongle with a working internet connection plan and also with a SD card slot, for using as a flash memory medium
A calculator-watch
Sports Wristband
A thin band (elastic)
A mirror stuck on a piece of cardboard
Step 1: Making the Miniature Essential Survival Kit
Picture of Making the Miniature Essential Survival Kit
Firstly, we will make the miniature essential survival kit which includes all the materials seen in the picture
Step 2: The Fire Essentials
Picture of The Fire Essentials
Take two matchsticks and the strip cut from the side of the matchbox
Step 3: BandAid
Picture of BandAid
Take the BandAid, which should preferably be of a well trusted company, for you cant take chances when on survival mode
Step 4: Writing Instrument
Picture of Writing Instrument
Take a thin ball pen refill, and cut it according to the size of the survival kit box
Step 5: Fitting the BandAid
Picture of Fitting the BandAid
Fold the BandAid according to the size of the kit box
Step 6: Fitting the Matchbox Strip
Picture of Fitting the Matchbox Strip
Fold the strip according to the need of crunching it in the kit
Step 7: Fitting the Matchsticks
Picture of Fitting the Matchsticks
Take the two matchsticks and cut them if necessary, but a suggestion is, try not to cut the matchsticks, for the more wood you have, the longer it will burn
Step 8: Fitting the Refill
Picture of Fitting the Refill
Take the already cut refill and fit it in the box
Step 9: Fitting Everything
Picture of Fitting Everything
Take the box
Step 10: Fit Everything
Picture of Fit Everything
Step 11: Making the Ultimate Wearable Survival Kit
Picture of Making the Ultimate Wearable Survival Kit
Take all the materials shown in the picture
Step 12: Take the Calculator Watch
Picture of Take the Calculator Watch
Make sure each key works
Step 13: The Dongle
Picture of The Dongle
Insert the SD card in the dongle and you get both the dongle and the pendrive
Step 14: Pocket Mirror
Picture of Pocket Mirror
Step 15: Elastic Band
Picture of Elastic Band
Step 16: Fixing the Objects
Picture of Fixing the Objects
Arrange and fix all the objects as shown
Step 17: Fixing the Objects
Fix everything and dont forget to attach the Survival Kit too
helloperson (author)2015-11-23
I'm going to make this, I'm going to try to fit some string into it also.
I think its awesome. Sometime I'm going to try to build this.
skumar231 (author)2015-11-30
Don,t worry about comment learn from comments and make a BEst compact survival kit....Thumbs Up...
ThePaulHammer (author)2015-11-26
You have none of the survival essentials other than fire, which is questionable because if you think 2 matches are enough then i doubt you can light a fire with one. You've got no way to purify water, no rope (an essential), no worthwhile first aid, no way to make any sort of shelter, and no redundancy whatsoever. And that mirror would be pretty useless, you'd wanna get an actual signaling mirror- that is something you can't afford to skimp out on. Which is funny because you said you don't wanna take chances in a survival situation when talking about the single bandaid you added. You might as well drop everything but the dongle.
Sayash (author)ThePaulHammer2015-11-27
You see, there is a limit on what all you can add to something wearable, but I will keep in mind your suggestions and make the version 1.1 better
ThePaulHammer (author)Sayash2015-11-28
Check out the micro survival kit builds, you'd be amazed how small they can get.
Jiajiun (author)2015-11-25
why you need SD card?
About This Instructable
763views
9favorites
License:
More by Sayash:Ice boxBucket Casserolesabudana khichadi
Add instructable to:
