Weather Matrix Display
5,072
51
16
Posted
Introduction: Weather Matrix Display
Internet of Things Contest 2017
Second Prize in the
About the project
I'll show you how to create a mini weather status display from a 8x8 matrix display.
I will be using Genuino MKR1000 to fetch temperature, humidity and condition of weather within a selected location.
Show status to display in an slide animation pattern.
Challenges
Since 8x8 Matrix is basically an array of LEDs, I will need to program it to show text and animation effects
On this project you will also learn how to
  1. consume rest web service api
  2. how to parse Json data
  3. how to use Threads and Wifi libraries in Arduino
Step 1: Assemble MKR1000 and 8x8 Display to Mini Bread Board
The setup is pretty simple, we just need to attach the 8x8 matrix display to our microcontroller.
Requirements
  1. 16pcs of Male to Female jumpers
  2. Mini Bread Board
  3. Microcontroller
  4. 8x8 Matrix Display'
Assembly Display
Divide your jumpers to group of 8pcs.
Make sure that the jumper wires are perfectly alligned.
Connect the 8 female jumpers to the first 8 pins of matrix display.
Connect the other 8 female jumpers to the 2nd 8 pins of matrix display.
Attach to microcontroller
Attach the microcontroller to the mini breadboard
Using the end male pins of the jumper wires, insert them on the first 8 holes where the microcontoller pins are attached (5-A5).
Insert the remaining on the other 8 holes where the microcontoller pins are attached (6-13).
Adjust the 8x8 Matrix Display so it is facing the front when you place it on the table.
Step 2: Create Your Weather Api Account
To be fully called Internet of Things, we need to fetch some data from the internet.
I used APIXU API to fetch weather data from my selected location.
Sign Up for the account here https://www.apixu.com/login.aspx and get your account API Key.
Feel free to use my own api key
String apiKey = "8f0ff191defb4a20b5583518171203"; // your apixu api key
Step 3: Flash Your MKR1000
Add the attached HexFont.h to your Arduino libraries.
Use attached simple_weather_display.ino to flash your microcontroller.
On this part of the code:
Replace with your WiFi settings
char ssid[] = ""; //  your network SSID (name)
char pass[] = "";    // your network password (use for WPA, or use as key for WEP)
Replace with your Apixu Api Key and location coordinates
String coordinates = "14.3335591,120.9758737"; // your location coordinates
You can also changed what data to be displayed on this part of the code
//update display text to new weather condition
    message = "";
    //get the current condition
    String condition =  result["current"]["condition"]["text"];
    appendMessage(condition);
    appendMessage(" ");
    String temp_c = result["current"]["temp_c"] ;
    appendMessage(temp_c);
    appendMessage("C");
    appendMessage(" ");
    String humidity = result["current"]["humidity"];
    appendMessage(humidity);
    appendMessage("H");
    appendMessage(" ");
For example if you want to add wind_mph from apixu api result:
String wind_mph = result["current"]["wind_mph"] ;
appendMessage(wind_mph);
appendMessage("Wind mph");
appendMessage(" ");
Step 4: Finish!
Once flashed it will try to connect to your WiFI and will fetch your weather condition, temperature and humidity!
Make sure you have internet connection.
Need Help?
Feel free to comment here.
Support the project from this Github repo
https://github.com/imjeffparedes/iot-simple-weath...
Also Please vote for me on Internet of Things Contest. :)
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    12 Comments
    I made it with 4 displays and with the ESP 8266 and it shows time and MUTCH more my name and info and youtube info, check my youtube or website for the video info
    www.wannaduino.com or search on GOOGLE for WannaDuino.
    I am NR 1 on google search so you will find me DIRECT. i am all for helping and OPEN SOURCE,
    Nice project, thank you for posting.
    I am now trying to convert it to run with MAX7219 matrix controller using just the three connections.
    please share code then, that was my thought also. wel done if you got it to work.
    That would be cool. Let me know when your done. :)
    can i not just use a wemos D1 and a MAX matrix with the display chip on it already??means LESS jumper cables AND CHEAPER. ( only 5 cables TOTAL )
    or do i miss something?
    www.wannaduino.com
    Sure you can. You just have to revise the part where I displayed the result. :)
    can you do that>? and put the code also here, please?
    nice project! ;-)
    Thank you. Very simple but effective, right? :)
    From Hive Electronics, if that was yours. Yes, I got the idea from EMILY. But this time the display can support all alphabets, numbers and some special characters that slides to left when set. (The hardest part since the display does not have its own driver :D)
