Material
- ID12 RFID reader
- ID12 breakout board
- 125kHz RFID Tag
- USB to serial adapter
- BlueSmirf Gold Bluetooth module
- Right angle break away headers
- Jumper wires premium F/F
- Ensto junction box IP55
- 3 1.5V AA batteries
- Battery holder with button connectors
- Battery wire with button connectors
- 2 short pieces of wire
- Solder
- Tape
- Cutter
- Soldering iron
- Helping hands
Remove these ads by
Signing UpStep 1Solder headers to the BlueSmirf Bluetooth module
Is it possible to do the same thing with a wifi module instead of Bluetooth?
Thanks.
... http://rfish.net/download/Serial.zip
it says "Forbidden" (error code 403)
yes, I did. That said, there's very little software included here. For a real application you'd probably need some extra code.
Cheers,
tamberg
Cheers,
Stephen in Montréal
Everything seems to be made correctly, yet it doesnt read the tags.
Would the ID 20 be the problem??
Regards out of N Zld
the main difference between ID-12 and ID-20 (according to http://www.sparkfun.com/datasheets/Sensors/ID-12-Datasheet.pdf) seems to be the power requirement. The ID-12 requires 5 VDC @ *30*mA, the ID-20 requires 5 VDC @ *65*mA nominal. While the ID-12 works fine with only 4.5 VDC, this might be too low for the ID-20. If you got a 5V power source you could probably use it instead of the 3 AA batteries. But still, the pin layout is the same on both readers, so I do not really understand either, why the reader doesn't work at all. Can you check the wiring again and make sure you use a EM 4001 or compatible RFID (125kHz)?
Cheers, tamberg
Some of the questions I have need to be moved to a less public forum can you email me at chris@o-t-s.ws.
Thank you
A laptop, an antenna, and some software to log the data, a brief case. All that is needed is a place to walk around and pick pocket people. An Airport is a good place to start.
This all can be done for a few hundred unless you already own a laptop the price drops, most things can be built or bought off ebay cheap the software can be found free and anyone can get a suit case or similar bag cheap.
I would like to know where you picked up your parts and how much. That is the main part of what I want to display to victims is how little it costs and how easy it is to get the designs to do this.
i am asking if you simulated this .. i mean is there any software simulation to simulate this if there is no way to execute it in real .. ?
thanks alot
in my graduate project i need to attach the bluetooth module to the RFID reader ( as you did physically by wires ) .. but it's not available to us to buy this components .. so , i wonder if there is a simulation contains the RFID package and how to communicate with Bmodule .. to simulate it rather than perform it in real because it's impossible ,, :(
is it clear ?
thanx ..
i saw ur video .. but they are connected physically , so i'm asking is there is any programming have been done so , they can " talk " to each other ?
thanks
Maybe it's best to look for RFID livestock identification to find something more suitable for animal scanning like http://biomark.com/ or http://www.allflexusa.com/eid/readers.php
Regards,
tamberg
Regards,
tamberg
It doesnt works, works only with ftdi usb-serial adapter. Its confirmed in the description of bluesmirf module in sparkfun website. TTL type only.
Thanks Tamberg, my device is working fine.
Can I use a prolific Usb to serial cable for configure the BT modem?
it works?
Thanks!
Regards,
tamberg
I will try when the parts arrive to me.
Greetings from Chile.
