Step 2Configure the BlueSmirf module via USB
- VCC to 3.3V
- GND to GND
- TX-O to RX-I
- RX-I to TX-O
Press "<Windows key>-R" on your keyboard to open the "Run" command line, type "devmgmt.msc" and press "<RETURN>". This opens the Device Manager. Open the node "Ports (COM & LPT)" in the device tree. There should be a node called "USB Serial Port (COM<X>)" e.g. COM17. Write down the COM port number (to talk to the BlueSmirf module over USB we will open a connection to this COM port).
Download SerialUsbBlueSmirfConfig.zip (requires .NET 2.0; source included for educational purpose) and unzip it.
Edit SerialUsbBlueSmirfConfig.bat (right click, "Edit") to match your COM port number and baud rate (default for BlueSmirf Gold is 115200 baud) and save the changes.
Start SerialUsbBlueSmirfConfig.bat and as soon as the program displays your COM port in the command shell, type the following commands (BlueSmirf's response shown in italic):
- $$$<RETURN>
- CMD
- SU,96<RETURN>
- AOK
- ---<RETURN>
- END
(Note: If you want to use SerialUsbBlueSmirfConfig.bat again don't forget to change it to 9600.)
It doesnt works, works only with ftdi usb-serial adapter. Its confirmed in the description of bluesmirf module in sparkfun website. TTL type only.
Thanks Tamberg, my device is working fine.
Can I use a prolific Usb to serial cable for configure the BT modem?
it works?
Thanks!
Regards,
tamberg
I will try when the parts arrive to me.
Greetings from Chile.
