loading
Step 2: Get Cutting
Cut the bottle in half (Remember your knife safety). This is also a good time to dry it out. (Remember, you will be putting electronics in here to protect it from water, so it should be dry).
You will also need to cut the cap. If you bottle has a sport/sippy cap, cut out the post holding the mouth piece from the inside. Check to see if the end if the USB cable slides in easily. If not, you will need to carefully cut a slit in the tube on the top of the cap.
If your water bottle has a normal cap, place the knife point in the center of the cap. careful not to cut or stab yourself or anything else, push the knife down, creating a slit. Now, on on the edge across from that slit, make another slit that meets the first slit in the center. In the same manner, continue making slits until you can easily push the end of the USB cable through the cap.
With the USB cable through the cap, screw the cap on to the top of the bottle.
100 Mile-an-Hour Duct tape?
Old comment...but 100 mph tape is a mil-spec tape. It's a raiting, not a brand name. It is similar to duct tape, but uses a stronger backing but with basicly the same adhesive. It's name comes from it supposedly being able to hold up to 100 mph winds, when used to patch tarps, tents or what ever. There is also 200mph, 600mph and 1000mph tapes. All with different backings and adhesives to give them their stronger rating. Most regular duct tape has a wind raiting of between 60-90mph so they are not the same tape. Those with the mil-spec raiting will say on the product that they are 100mph tape.
<p>This look pretty decent, I'm going to try this and does this pick up it's own Wi-Fi or somebody else's Wi-Fi.</p>
The wifi adapter in a close bottle,i don't think its a good idea in summer to proof water.anyway,the temp. is very high,when it works
It worked just fine in the 120+ F summer of Iraq. Waterproofing also protects against sand and dust.
Under what circumstances would you need to weatherproof your wireless router but not your laptop itself... o__O
Well, in Iraq the wireless signal is very weak inside the trailer in which the service members and civilian contractors live. Since wireless connections are all that they have, one needs a weatherized adapter. RVs and travel trailers may encounter similar problems. Honestly, this is mostly for the troops, but maybe someone could make an Instructable about weatherizing a laptop.
&nbsp;2 words: tough book best computer ever completely indestructable. The only thing it couldn't withstand was a bullet from point blank range. Oddly enough it held together sitting on a few pounds of dynamite.....
Yes tough books are great, but unless you plan to sit on your porch to get wifi in Iraq, you'll still need something like this. I must say I firmly believe a tough book could survive being used outside during a sandstorm; even so, I would rather be inside.<br /> <br /> Cheers<br />
DAng it! you beat me to it!!
dont forget to add silica gel packets in it to prevent condensation
That's a good idea. <br />
you could get even more sun protection lining with a mylar chip bag, shiny side out, though they also make pretty good emf shielding so don't go all the way around, just put it on the sunward side of the bottle. foil or metallic paint (on half the inside) might work too. the shade material could be installed on a well ventilated 2L bottle which encloses the smaller one the way it encapsulates the adaptor, but maybe that is adding too much weight and bulk.
thats a nice idea but with base security stuff there a small reflective bottle just screams come harrass me
the reflector wouldn't have to be the outermost layer to do some good, that could be a light coloured paper with the mylar or foil inside/behind it.
We never had any problems at Camp Victory, but mat white paint would also make it so it isn't shiny.
So wait, does this adapter work anywhere in the world or only when wireless networks are in range?
Why not just run the Aerial outside?
Nice! Just so you know, I should be your favorite sister because I voted for you!
love your knife:)
Thanks. It's the special edition OIF Syderco.
Cool!!!
sweet idea! im going to make it right now!
5*
About This Instructable
20,442views
37favorites
License:
More by fgibbs:Traffic Cone Christmas Tree Adjustable Weight Indian Clubs Hearth Bread
Add instructable to:
