Introduction: Web Manager Development for WIZnet Serial to Ethernet Modules
Picture of Web Manager Development for WIZnet Serial to Ethernet Modules
WIZnet Serial to Ethernet (S2E) Module provides Serial AT command and configuration tool to monitor and control current mode of the device such as device setting, current running mode and connection status.
To improve the existing module's control feature, I have proposed 'Webmanger'.
With the Webmanager, a user can easily perform monitoring and controling task of an individual (S2E) module where the controlling and monitoring result can be deployed to setup initial values and debug errors.
This is a brief summary of webmanger in prototyping stage and still on a development process. This project is based on HTTP Server library in WIZnet.
Step 1: S2E Concept
Picture of S2E Concept
S2E?
Serial to Ethernet (S2E) module is the protocol converter that transmits the data sent by serial equipment as TCP/IP data type, and converts back the TCP/IP data received through the network into serial data to transmit back to a serial equipment.
Currently, WIZnet provides the following two method for setting up the S2E products.
  • Serial AT commands
  • Configuration tool program (figure above)
Step 2: Parts
Picture of Parts
I was made a development environments for the demonstration. This evaluation board is much similar hardware as the WIZnet WIZ550web products, it will be to change for purpose.
Typical specifications for the product are as follows.
  • MCU
    • STMicroelectronics, STM32F103RCT6
    • Cortex-M3 up to 72Mhz, 256kB code flash memory, 48kB SRAM
  • Ethernet Controller
    • WIZnet W5500
    • Hardwired TCP/IP chip, High Performance SPI Interface
Step 3: Used Libraries
WIZnet HTTP Server Library. Please refer to the next link.
https://github.com/Wiznet/HTTPServer_LPC11E36_LPCX...
Step 4: Implemented Web Manager Prototypes
Picture of Implemented Web Manager Prototypes
Considered elements to make a Web Manager are as follows.
  • AJAX / Responsive Web
    • Corresponding to the mobile environment
  • S2E Device Status Control / Monitor
  • Real-time Data Transaction Monitoring Chart
  • Configurable I/O Settings
  • Useful Links (FAQ / Wiki / Forum ... and Etc.)
Step 5: Plans
Picture of Plans
  • Real-time Data Transaction Monitoring Chart Page
    • Monitoring result can be deployed to setup initial
  • Configurable I/O Settings Page
About This Instructable
336views
5favorites
License:
Bio: Embedded Firmware Engineer / Researcher. I'm Interested in IoT platforms and OpenSourceHardWare like arduino, Cloud, Web / App and product development.
More by Eric.Hyungki.Jung:Building Your Android Apps for monitoring IoT devices using REST APIAdding REST-based Web Services to IoT Device for IO monitoringWeb Manager development for WIZnet Serial to Ethernet modules
Add instructable to:
