Remove these ads by
Signing UpStep 1What you will need
1. Plumber's hanger iron. It's sometimes called Plumber's Tape, but don't confuse this with teflon sealing tape. Hanger iron is available at any hardware store in the plumbing section. It is simply a roll of sheet metal that's about 1.5 cm wide, .5 mm thick, and maybe 3 meters long, and it has holes punched into it every cm or so. You will only need about 30 cm of it, but a roll of it can be had for under $3, and it can be used for lots of things.
Electrical tape. This is for padding the metal and covering any sharp edges.
You will need a hammer and a decent-sized set of pliers for bending the hanger iron. The pliers pictured here are Vise-Grip locking pliers, but any set of pliers will do.
Add Comment
