Introduction: Wedding DIY: Table Numbers
Summer is officially here, and with it comes wedding season. We’ve created a series of wedding-themed DIYs, and the first is a set of table numbers that double as water bottles.
Step 1: What You’ll Need:
- Latch-top water bottle
- Mod Podge
- Gold glitter
- Paintbrush
- Stick or toothpick
- Gold vinyl
- Silhouette Cameo vinyl cutter
- Lust Script by Neil Summerour
Step 2:
Cut out each number on the gold vinyl using your Silhouette cutter. We choose Neil Summerour’s Lust Script because it’s elegant but modern. If you don’t have a Silhouette Cameo cutter, you can cut the letters out by hand.
Step 3:
Squeeze a small amount of Mod Podge on a plate or palette and start painting glue on top of the numbers.
Step 4:
Once you’ve finished gluing, immediately start sprinkling your sparkles evenly over the number.
Step 5:
Using a toothpick, gently trace around the edge of the number, making sure the edges stay clean and crisp.
Step 6:
Let your number dry for about 20 minutes and then gently peel off and stick to your bottle.
Step 7:
Repeat the above steps for the remaining tables and you’ll have cute table numbers that also serve as water bottles.
