Wedge and Feathers for Rock Splitting (or Plug and Feather)
Published
Introduction: Wedge and Feathers for Rock Splitting (or Plug and Feather)
The image of wedge and feathers is taken from the internet. The dimensions of the original tool are different.The tool is for a hole with diameter 22mm.
Step 1: Wedge
For the wedge I used a piece of steel, 1,5 cm thick. Then I cut a piece 20 cm in length
Step 2: Dimensions of the Wedge
The biggest part of the wedge is 24mm and the smallest is 7mm. Mark the wedge with a pencil and cut it.
Step 3: Cutting the Wedge
Cut the wedge with an angle grinder
Step 4: Final Piece of Wedge
Picture of the final piece of wedge. The final piece of the wedge should be like this
Step 5: Feathers
For the feathers I used construction steel bars 19 cm in length. Cut 2 of these.
Step 6: Dimensions of the Feathers
The diameter of the two feathers should be 22mm. To achieve this, it's better to cut the steel bars with an angle.
Step 7: The Final Piece
The final piece should be like this. Cut other 2 or 3 to break the rock easily.
Step 8: The Results
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    3 Comments
    What did you use to cut the metal? A torch, a saw?
    How well would you say it worked? How well did the wedge and feathers hold up?
    How long did it take to make them?
    I used an angle grinder for the cut. To keep them up, simply i filled the hole with soil.
    https://www.youtube.com/watch?v=M5JeIM4WjwI
