Step 6Wiring on the right hand side
iImage Information
The easiest way to avoid cable chaos is to use connectors. I used them to connect one side of the body with the other. Because I milled already on the left side some plastic for the cables from the foregripp to the MP5 body away I used some heat shrink tube on the right hand side of the MP5 body and hotglued the cables to it. on the backend part of the body I used the male connectors and on the other side the females. Because there was a little plastic pin on both sides of the body it was easy to fix them in the right place. On the other body half I connected all the buttons with the cables coming from the Wiimote board. Except the battery cables! I decided to make it easier when adding a charger in later projects I will need them!
