Weed Eater motor Bike(Friction Drive) by Hackrtanman
This is my Weed Eater motor powered bike. It is friction drive, as you can see, and is mounted using steel. We were thinking about aluminum, but it might be to light and not strong enough. the drive shaft is on of the stunt bike pipes. The hardest part was the mounting technique, mainly because the motor hardly have any good mounting spots. Credit to my dad for helping with the mounts, and without using a welding torch! Enjoy!
kdf.inc1969 says: Sep 9, 2012. 4:53 AM
yes, could you make an instructable? i would love to find out how this was attached without welding. since i cant weld.
chiefs543 says: Apr 29, 2012. 4:29 PM
How do you put the peg on the clutch shaft? Can you u just thread it with a tap and die? Would it work if you just mounted the clutch shaft against the wheel without the peg on it?
Masterchaos98 says: Apr 3, 2012. 10:44 AM
I thought that you were supposed to give instructions on how to make it
Aron313 says: Mar 30, 2012. 4:33 PM
What size engine is it? And how does the power do with all the weight on it? Like climbing hills?
MackeFeet says: Jul 25, 2011. 5:41 PM
For me, that toro would be a very big engine to run on a bmx bike like the one you have... I don't know about how it is to actually ride but for a probably 25-30cc motor I think the size and weight would slow it down.. Just my opinion...
Hackrtanman (author) says: Jul 25, 2011. 10:33 PM
Yes, but after I modified the attachment system from being forced down to only gravity, it worked a lot better.
MackeFeet says: Jul 31, 2011. 12:06 PM
Yeah.. Okay I see why you mean...
Enzomatico says: Jul 5, 2011. 9:07 PM
hey I used a 11/16 inch socket as my drive shaft and it doesn't grip the tire well enough because its smooth. Do you think if i get a bike peg that has grooves like yours do you think it will grip better? thanks
Hackrtanman (author) says: Jul 6, 2011. 10:16 AM
Yes, it will work alot better, but also, make sure the motor is loose and can move up and down on the wheel, so its not tight.
Enzomatico says: Jul 6, 2011. 4:53 PM
does the tire tread matter? because on my bike the tread is completely flat.
Hackrtanman (author) says: Jul 8, 2011. 7:46 PM
No, but I highly recommend have some tread. Go to a bike shop and get treaded tires
11richie21 says: Jun 13, 2011. 2:08 PM
does the motor always spin in the same direction?? i have a leaf blower gas motor but i dont know which side to put it on
Hackrtanman (author) says: Jun 14, 2011. 8:58 PM
you want it to go opposite of the way the wheel spins, in the case, your looking at it spinning clockwise
11richie21 says: Jun 16, 2011. 6:14 PM
thank you once i get a welder im going to finish this project
TheMaker888 says: May 15, 2011. 9:13 PM
your fork is on backwards by the way..
Hackrtanman (author) says: Jun 14, 2011. 8:56 PM
Yeah, i realized that later
rreda says: Jun 13, 2011. 1:59 PM
what i should have do this ?????????
Wareagle says: Apr 24, 2011. 7:38 AM
I am building one of these, but i ran into a problem. how do you keep the bike peg from unthreading itself when its on the bike?
Hackrtanman (author) says: Apr 26, 2011. 5:00 PM
the peg is put on reverse
PWNDbyNooB says: Oct 12, 2010. 7:09 AM
cool...o i made an account now :) mason
Hackrtanman (author) says: Oct 13, 2010. 4:10 PM
awesome
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
