3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Weekly Project: Voltoids; or, How to Make 5V from 1.5V
Step 2Board or Freeform?
Board or Freeform?
You can build this circuit on a small piece of perforated prototyping board. If you elect to go this route, you might also want to use an 8-pin uMax adapter for holding the MAXIM chip. Be forewarned, this adapter is not the same as the more common 8-pin IC socket. Although untested, try this MSOP-8 adapter from Digi-Key #33108CA-ND.
If you're more adventurous, you can build this entire circuit freeform. In other words, solder all of the components together without using a board to hold them. Please note that a soldering iron can and will burn off a leg on the MAX1674 with too much heat.
Either way this project is for the advanced electronics builder. Just go slow and don't burn your fingers.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:PopSci
