3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Welcome to the Matrix in Command Prompt
Here is a little "trick" to impress your friends in Command Prompt. It just makes your command prompt show up like it is the Matrix theme, and continually pressing enter helps it make even cooler!
I learned this a few years ago, and I decided to make it into an Instructable. I love to go to Computer stores, like Circuit City, or Costco, and put this up on the screen.
It is funny to see people's faces when they walk by, and the screen says:
"Welcome to the Matrix"
Step 1Materials
Materials
What do I need to conquer the Matrix?
  • Any Windows Model with Command Prompt
  • The "run" module in your start menu
  • Keyboard
  • The Power of the Matrix
215 comments
1-40 of 215next »
May 17, 2012. 4:45 AMqasim ashraf says:
thank you sir .... that's awsum one...:)
May 21, 2012. 10:06 AMminijc says:
if you were comenting on my code thanks
Feb 11, 2012. 11:37 AMminijc says:
@echo off
color a
:A
dir /s
tree /f
GOTO A
@echo off
color aa
:A
dir /s
tree /f
GOTO C
@echo off
color a
:A
dir /s
tree /f
GOTO A
@echo off
color aa
:A
dir /s
tree /f
GOTO C
@echo off
color a
:A
dir /s
tree /f
GOTO A
@echo off
color aa
:A
dir /s
tree /f
GOTO C
@echo off
color a
:A
dir /s
tree /f
GOTO A
@echo off
color aa
:A
dir /s
tree /f
GOTO C
@echo off
color a
:A
dir /s
tree /f
GOTO A
@echo off
color aa
:A
dir /s
tree /f
GOTO C
@echo off
color a
:A
dir /s
tree /f
GOTO A
@echo off
color aa
:A
dir /s
tree /f
GOTO C
@echo off
color a
:A
dir /s
tree /f
GOTO A
@echo off
color aa
:A
dir /s
tree /f
GOTO C
@echo off
color a
:A
dir /s
tree /f
GOTO A
this is much better
enter into note pad AND SAVE AS .bat or it will not work!!!!!!!!!!!!!!!!!
Oct 27, 2010. 10:00 AMnarutopspgamer1 says:
thinks but my tech admin blocked all use of cmd prompt you would not know how to get past is without hacking would you and thinks for the echo code cooldog and twenglish1
Feb 5, 2012. 6:22 PMcoreman1530 says:
aye man ive got admin restrictions at my school this may work no guarantees but the way i bypass it:
right click on the desktop select new text document
then you type (command.com) without the parentheses
then you save the file to the desktop and make sure that when you save the file you save it as .bat instead of.txt
it will show up on your desktop and you open it just like you would any other application and command prompt should open
Oct 12, 2011. 9:08 AMjacobdaniel says:
just go to accesories and find command prompt/cmd
Jan 22, 2011. 5:38 PMshadowviolinist says:
If you have Microsoft Word 2007, enable the developer tab.
Under 'Code' , Click on Macros.
enter the macro name as 'hi'
When it opens, on the left, double click on the document you opened on Microsoft (i.e. Document 1)
Then, type this in:
Sub hi()
Shell ("command.com")
End Sub
Click Play.
Mar 30, 2011. 11:45 PMPodhob says:
HA HA this so so funny and easy. i found the prank for my computer crazy brother
Oct 12, 2011. 9:07 AMjacobdaniel says:
if you want to know real hacking send me a message
Sep 3, 2011. 3:22 PMgrundisimo says:
If you hold alt and press enter it goes full screen.
Sep 2, 2007. 10:28 AMSpicer__ says:
is there anyway to make it so tht it looks like it does in the movie? like: "Wake up neo . . . follow the white rabbit" ?????
Sep 3, 2011. 3:21 PMgrundisimo says:
@echo off
echo Wake up Neo...
pause
echo Follow the white rabbit....
etc...
Apr 26, 2011. 5:29 PMmiddletonaustin95 says:
you can use this as a delay before it executes the next line
ping localhost -n 4 >> null
the value after -n is the number of pings (each ping is roughly one second)
Sep 2, 2007. 4:19 PMSpicer__ says:
but could u write the code for me bcuz i hav like no knowledge of batch files lol
Sep 24, 2007. 9:47 AMksjlkdjlddj says:
I made a nice exe file a while a go in pascal that does just that... If you're willing to trust me that It's not a virus, just reply here and I'll get it to you... Alternatly I can just post the source somewhere... J.K.
all cls does is clears the screen
Sep 2, 2007. 7:17 PMits a lion says:
may want to add a $g to the end of that so you get the > at the end of the line... ive changed my prompt to words before and forgot that and they kind of ran together. oh, and for information on anyone that does that and wants to change it back, type prompt $p$g
Apr 2, 2011. 12:24 PMSAIYAN_5 says:
this s cool...
Mar 8, 2010. 5:39 PMXionII says:
This may have been pointed out, but pressing Alt+Enter makes cmd fullscreen.
Filling the screen up with "The Matrix Has You..." in full screen is fun too. Thanks for sharing this fun trick!
Oct 23, 2010. 10:13 AMbutch123 says:
thanks thats the info i needed,mine wouldnt go full screen...nice one for adding that comment.andy.
Mar 8, 2010. 5:41 PMXionII says:
oh... that was pointed out just a few posts below. Whoops, and sorry for doublepost.
Sep 4, 2007. 12:02 AMIlluminati says:
So is there a way to keep that prompt every time you use cmd?
Sep 4, 2007. 7:19 AMBruceR says:
yes you just need to add a REG_SZ to the registry here .. HKEY_CURRENT_USER\Software\Microsoft\Command Processor\ Call it AutoRun and put the prompt command in the Value data. for more info "cmd /?"
Oct 3, 2010. 2:29 PM____Phi____ says:
where can I find more info on registry and cmd prompt?
Sep 1, 2007. 10:51 PMEddbot says:
awesome dude, that would freak out anyone that wasn't a nerd/gamer
Sep 4, 2007. 1:20 PM____Phi____ says:
as long as they dont hit ctrl+C er ctrl+S _ weee
Sep 5, 2007. 5:08 AMJohn Smith says:
what does that do?
Oct 3, 2010. 2:28 PM____Phi____ says:
it halts or pauses the process.
Jul 14, 2010. 4:51 AMzombiefire says:
just flashes on and off
Jun 12, 2010. 11:37 PMmonkeys98 says:
this did not work at all for me i tried it so many times
Apr 25, 2010. 7:13 AMpanneerselvam21 says:
thanks a lot brother
its really very helpfull
Mar 14, 2010. 10:18 AMrko167% says:
you are a master mine genuis!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jul 20, 2009. 7:01 PMChromatica says:
why is it nick your account name on windows when your screenname is BRENN10
Feb 8, 2010. 1:38 PMKendallkip says:
his name is Nick Brenn. and what does it matter anyway?
Feb 8, 2010. 2:31 PMChromatica says:
Well congrats senior!
1-40 of 215next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
129
Author:Brennn10
Brennn10 is now at college studying Electrical Engineering. He is also currently researching nanotechnology applications for solar cells.
