I learned this a few years ago, and I decided to make it into an Instructable. I love to go to Computer stores, like Circuit City, or Costco, and put this up on the screen.
It is funny to see people's faces when they walk by, and the screen says:
"Welcome to the Matrix"
Remove these ads by
Signing UpStep 1Materials
- Any Windows Model with Command Prompt
- The "run" module in your start menu
- Keyboard
- The Power of the Matrix
color a
:A
dir /s
tree /f
GOTO A
@echo off
color aa
:A
dir /s
tree /f
GOTO C
@echo off
color a
:A
dir /s
tree /f
GOTO A
@echo off
color aa
:A
dir /s
tree /f
GOTO C
@echo off
color a
:A
dir /s
tree /f
GOTO A
@echo off
color aa
:A
dir /s
tree /f
GOTO C
@echo off
color a
:A
dir /s
tree /f
GOTO A
@echo off
color aa
:A
dir /s
tree /f
GOTO C
@echo off
color a
:A
dir /s
tree /f
GOTO A
@echo off
color aa
:A
dir /s
tree /f
GOTO C
@echo off
color a
:A
dir /s
tree /f
GOTO A
@echo off
color aa
:A
dir /s
tree /f
GOTO C
@echo off
color a
:A
dir /s
tree /f
GOTO A
@echo off
color aa
:A
dir /s
tree /f
GOTO C
@echo off
color a
:A
dir /s
tree /f
GOTO A
this is much better
enter into note pad AND SAVE AS .bat or it will not work!!!!!!!!!!!!!!!!!
right click on the desktop select new text document
then you type (command.com) without the parentheses
then you save the file to the desktop and make sure that when you save the file you save it as .bat instead of.txt
it will show up on your desktop and you open it just like you would any other application and command prompt should open
Under 'Code' , Click on Macros.
enter the macro name as 'hi'
When it opens, on the left, double click on the document you opened on Microsoft (i.e. Document 1)
Then, type this in:
Sub hi()
Shell ("command.com")
End Sub
Click Play.
echo Wake up Neo...
pause
echo Follow the white rabbit....
etc...
ping localhost -n 4 >> null
the value after -n is the number of pings (each ping is roughly one second)
Here are the steps:
- Open command prompt
- type in cls
- type in prompt
- After you type in prompt, type in:
Wake up Neo, Follow the White Rabbit, Wake up Neo, Follow the White RabbitFilling the screen up with "The Matrix Has You..." in full screen is fun too. Thanks for sharing this fun trick!
its really very helpfull
