Weld a Spoon Flower! by blrplt1
Featured
Create an attractive trash-to-treasure flower to put in your flower bed or urban garden! This is a neat little metal sculpture project that you can complete in just a few hours, but will add some permanent shine wherever you plant it!
Credit for this idea goes to an unknown metal artist I saw at the 2009 Rochester Lilac Festival. Drop by next year and see if you can find him.
http://www.lilacfestival.com/
And if you don't mind, please rate this Instructable and leave me some critical feedback!
Step 1: What You'll Need
Materials
1.Silverware- For this flower, you'll need 8 large soup spoons, and 2 forks. It's easy to pick up used silverware at minimal cost at garage sales, commission shops or auctions. The thicker and heavier, the better. Just make sure your flatware is stainless steel, and not your mom's long lost heirloom silver collection. Silver is worth far more in whole form, and it won't weld properly anyways!
2. Ladle Scoop- You'll need one stainless ladle scoop, either from a broken ladle, or perhaps liberated from a used utensil. A similarly sized stainless steel cup or bowl could work as well.
2. Metal Rod- Any sort of steel scrap you have laying around will work- or you can buy 1/2" steel re-bar at most hardware stores.
My costs for this project have hovered around $3 for the silverware and steel rod.
Tools
1. Welder- I use a home-built microwave in the true DIY spirit, but MIG or TIG would be much more precise. The design of the flower could be adapted to use a spot welder too. By the way, this project is a great excuse to build a welder! See the links below.
2. Weld Rods- I cannot justify the cost of stainless weld rods on a project that should only cost
$3-5, so I used some 3/32" 6013 mild steel weld rods I had lying around. They do not do a beautiful job, but most of the welds are hidden. I would recommend using a similar cheap, mild steel weld rod for cost reasons, but you can use whatever you want!
3. Clamps- At minimum, you'll need a clamp or two to hold things in place while you weld. Some vie-grip clamps would be ideal. As you'll see, I found it easier to use some large steel pieces to hold the spoons in place. Bottom line, use what you've got.
4. Hacksaw- to cut the silverware.
DIY Welders
http://www.instructables.com/id/Weld/
http://www.instructables.com/id/SolarWelder/
http://www.instructables.com/id/Build-a-Microwave-Transformer-Homemade-Welder/
http://www.instructables.com/id/Homemade-Spot-Welder/
Step 2: Cut the Spoons
The first thing you'll need to do is cut the spoon handles down to size.
Arrange a pair of spoons opposite each other under the ladle, so that there is some length of handle outside the ladle edge. We'll need this later in order to bend the spoons. Then, lift the ladle and mark across the center of the spoons. Go ahead and mark the rest of the spoons to the same length.
Using the hacksaw, cut all the handles off at the place you've marked.
Step 3: Weld the Spoons
Next, we'll be welding the spoons together to create the petals. This process is designed to be arc welder friendly, but if you used a different process (MIG, TIG, etc.), you could weld the spoons directly into the ladle.
Take two of the spoons, and butt their cut ends together. Using clamps, or something heavy, fix the spoons in place. Weld the pair together. Repeat this for all the spoons, forming four welding pairs.
Next, using the same fixturing method, weld each pair together in the center. Weld each pair on individually, arranging them evenly to create the flower petals.
Step 4: Assemble the Flower
Next, we'll bend the flower into shape, before we add the ladle. Clamp the assembled flower in the center, and begin bending the spoons up where the handle merges with the spoon. Bend them all up about 30 degrees.
Next, place the ladle into the cup formed by the spoons. You may need to adjust your bends so that it fits in properly. Place the flower facing up, and tack the edge of the ladle in place with one of the spoons. This step can be difficult, since you're welding thin stainless with a not-so-precise arc welder.
I've found the easiest way to do this is to weld to the thickest spoon handle you've got, weld on the outside of the ladle, and make sure that the spoon you're welding to is well supported. Otherwise, you may end up cutting off the spoon altogether. While you can always weld it back on, it's frustrating.
Don't bother tacking the ladle in more than one place- if you get it tacked well in one spot, it'll hold fine and help conceal the welds better.
Step 5: Add the Stem, Leaves
Finally, we have to weld the stem onto the flower, and leaves onto the stem. Tacking the steel rod or re-bar you're using is easy- just clamp it onto the center weld where all the spoon ends terminate and weld it on. Unlike most of the rest of the project, there's plenty of material to weld to here. I suggest putting the flower at an angle, rather than perpendicular to the rod- it just gives a better presentation.
Leaves are the final touch. Clamp the forks onto the rod wherever you like. Tack the forks on, then bend the forks outward so they resemble some sort of garbage can foliage.
In order to preserve the non-stainless steel parts a little better from rust, you can spray down the stem and underside of the flower with some clear coat acrylic spray paint.
All done! Go plant your masterpiece in your garden or give it away as gift- people love these.
And remember, this is art- experiment and create new hybrids! (And monsters...)
gracediyer says: Jul 19, 2010. 7:07 PM
This makes me want to learn how to weld.
partsguy64 says: Feb 3, 2013. 8:21 PM
i already know how to weld and im a junior in high school and female
DanielO says: Feb 16, 2012. 6:35 AM
I was unaware stainless could be welded by anything but stainless rod, will a steel wired mig weld stainless also?
robsmtbike says: Dec 19, 2010. 12:46 AM
I just made one of these.. i had problems welding the spoons together and only ended up with 4 petals. I used the handles from the spoons as the leaves.. Thanks for the idea..
WhyHello says: Dec 3, 2010. 9:58 AM
cool :3
clever gift too :)
cdawisconsin says: Dec 3, 2010. 8:26 AM
Just added this project to my favorites. Learning to weld is on my "LIST"
hippiecoffee says: May 25, 2010. 12:26 PM
so I tried the lowest setting on my wire feed welder and just a tack weld and keep melting my spoons. any Ideas I also tried JB weld and came apart in the heat
redhoss says: Apr 8, 2010. 11:05 AM
Dude, I made one of these years ago except I flattened out my spoons. I also made a humming bird,butterfly and a stork (scissors for the beak).
bazookaromz says: Feb 20, 2010. 2:56 PM
 so beautiful! great job :)
got2bskilled says: Jul 21, 2009. 10:02 PM
I would love to see one that spins in the wind! Very NICE! I wish I could weld~
spylock says: Jan 6, 2010. 12:51 AM
Youre right,one could put a slight angle on the spoons and put a bolt through the middle and have spinning spoons.
guitarman63mm says: Aug 19, 2009. 10:38 PM
Bravo, I may just make this tomorrow with another 'layer' of spoons!
porcupinemamma says: Jul 4, 2009. 2:43 AM
LymanB says: Jul 2, 2009. 6:24 AM
Great project! I'd love to see this as a wind-driven decoration.
l8nite says: Jun 30, 2009. 5:54 PM
really neat project but what caught my eye was the welder, can you do an instruct on it or at least some photos and explanations?
Germy says: Jun 30, 2009. 12:46 PM
Nice project and great instructable. Instead of forks for leaves, you could try curling and welding on the other half of a few of the spoons.
thepelton says: Jun 30, 2009. 12:37 PM
Just make sure it doesn't collect water that could serve as a hatching place for mosquitoes.
Robocody says: Jun 30, 2009. 9:49 AM
Cool...
ML2009 says: Jun 30, 2009. 7:34 AM
Nice looking project but you may want to consider different materials or a different method of attachment. Welding stainless steel produces hexavalent chromium vapors. Even if you're welding outside, you'll be breathing in hexavalent chromium and getting covered in it.
See Wikepedia http://en.wikipedia.org/wiki/Hexavalent_chromium and read the section on Toxicity.
blrplt1 (author) says: Jun 30, 2009. 8:49 AM
While hexavalent chromium is a danger while welding stainless, your exposure welding a couple of these would be miniscule- assuming proper ventilation. Should you decide to go into the "flatware-flower" industry on your own, that's a different story. That said, good point, and a mask or basic respirator would be a good equipment choice for this project.
Here's an interesting bit on OSHA limits and protection methods for higher volume industry:
http://www.ewi.org/pdf/company/news/Hexavalent%20Fumes.pdf
valhallas_end says: Jun 29, 2009. 8:51 PM
Was that the booth with the eagle made of silverware, and the dragonflies and such with cheese grater wings? I always thought that guy had some impressive talent - I could barely lift one of his statues a few years back - a full-sized heron of all kinds of cutlery. I've wanted to play around with this stuff for years, but have yet to get a welding rig...no room to work. Nice 'ible though.
blrplt1 (author) says: Jun 30, 2009. 4:55 AM
Could be, but I didn't see anything other than variations on this flower. Might be someone else. You've given me some ideas though!
Calorie says: Jun 30, 2009. 12:30 AM
That came out looking nice. Well done.
wgrazier says: Jun 29, 2009. 9:02 PM
Wow! I love this project. I haven't welded since highschool and I probably won't do this but it looks gorgeous!!!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
