3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Weld a Spoon Flower!
Step 3Weld the Spoons
Weld the Spoons
Next, we'll be welding the spoons together to create the petals. This process is designed to be arc welder friendly, but if you used a different process (MIG, TIG, etc.), you could weld the spoons directly into the ladle.
Take two of the spoons, and butt their cut ends together. Using clamps, or something heavy, fix the spoons in place. Weld the pair together. Repeat this for all the spoons, forming four welding pairs.
Next, using the same fixturing method, weld each pair together in the center. Weld each pair on individually, arranging them evenly to create the flower petals.
1 comment
May 25, 2010. 12:26 PMhippiecoffee says:
so I tried the lowest setting on my wire feed welder and just a tack weld and keep melting my spoons. any Ideas I also tried JB weld and came apart in the heat
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:blrplt1
