Welded Bouquet
850
25
Published
Introduction: Welded Bouquet
Simple welding project
Tools used:
  • sheet metal cutters
  • vice, pliers, hammer
  • MIG or TIG welder
  • angle grinder
  • bench grinder, belt grinder
  • dremel
  • chisel
Parts:
  • nuts
  • screws
  • washers
  • nails
  • sheet metal
Step 1: First Flower
Base - screws
Petals - washers
Step 2: Second Flower
Base - screw
Petals - nuts
Step 3: Third Flower (Rose)
Based on great instructable Stainless Steel Rose from Scrap Metal
Petals - many pieces of sheet metal
Step 4: Stems and Base
Base - large nuts
Stems - nails
Step 5: Leafs
Leafs are stamped with a chisel to give them more natural look
Step 6: Final Assembly
Done, do not water to prevent rust ;-)
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    2 Comments
    Could you use soldering to hold the pieces together?
    I have never tried to solder steel, but I think it would be possible.
    Making the rose from copper sheet pieces soldered together would be quite easy.
    However, if you don't have access to the welder, I would consider using some two compound epoxy to glue everything.
    Also, have a look at this instructable https://www.instructables.com/id/How-to-Make-a-Metal-Rose-Without-Welding-and-Forgi/
