3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Welding Capri Sun Pouches
I'm a little miffed at Kraft for heavily marketing these things because they aren't recyclable.  So instead of doing something about it, they engaged in a distraction campaign with their Terracycle program.  But at least you can earn money for your kids school which is cool.
Unfortunately I can't get completely miffed about it because I love a couple of flavors of capri sun.  Plus it's handy as heck to pop them in the freezer then pop them in my lunch box cooler.  They serve a dual purpose here.  They keep things cool in the lunchbox cooler, and by the time lunch is around they have thawed out.
The other thing I love about these things is all the cool things I've seen people make with them.  Wallets, purses, bags, you name it.  Just do a google search for "capri sun projects" or "DIY capri sun".  You'll see what I mean
I have a bit higher aspirations than that.  I want to try making an umbrella or a tent out of them.  But the tent might be a bit ambitious.  Most people sew them together with thread, fishing line, or upholstery thread.   Or they will tape them together with Duct Tape or Gorilla Tape.  I wanted to weld them together.
At first I looked into how they do it industrially.  Apparently they either use microwaves or ultrasonic welding.  Do-able, but not for everyone.  Certainly not with parts I had laying around the house, and certainly not cheap.
In the end I found a soldering iron or wood burner works like a charm.
Step 1The science...
The science...
So a little google-ing and I found what they are made out of...
What is CAPRI SUN packaging made from? Is it recyclable?
CAPRI SUN pouches are polyester-reverse side printed to aluminum then laminated to polyethylene (a plastic polymer). Unfortunately, this packaging is not recyclable.
So it looks like a laminate of aluminum foil and polyethylene.  Ok fine.  What is the melting temperature of polyethylene?   A quick trip over to Wikipedia and I had my answer.  I love Wikipedia, best invention ever.  The nobel prize should go to the guys that invented it.  They are certainly more deserving than a couple of the past winners.
From Wikipedia:
For common commercial grades of medium- and high-density polyethylene the melting point is typically in the range 120 to 130 °C (250 to 265 °F). The melting point for average, commercial, low-density polyethylene is typically 105 to 115 °C (220 to 240 °F).
Ok so the melting point is somwhere between 220°F (115°C) and 265°F (130°C).  Ok, that shouldn't be a big problem.  I think clothes irons only get up to about 200°F so I'm thinking an Iron wouldn't work.
24 comments
Aug 4, 2010. 4:58 PMsculptur says:
thanks awesome ible im going to try to make a back pack as soon as i get enough pouches :)
Nov 18, 2010. 3:19 AMMonkey1234 says:
Hi I work for a well known drinks co. In the uk and I have a lot of brand new unfilled and unsealed Capri sun pouches I had the idea of filling them with alcohol like vodka "" to make those expensive nights out a bit cheaper" lol I see ur quite interested in these pouches if u like I can send u a bunch through the post let mr know .. Ps not sure if ur aware but the unsealed packs have a strip of heat activated adhesive built-in at the top..
Jan 24, 2012. 4:58 PMCosmicBrambleclaw says:
If you still have them I would love to get some :D
Oct 2, 2011. 1:43 PMRaisingAlexis says:
I'd love to put your pouches to use - we are trying to collect them for our Girl Scout Troop to use for a charity project. If you are still interested in passing them on, please let me know! Thanks.
Aug 27, 2011. 6:39 PMMisstongshil says:
hi~! this was pretty cool! just wanted to comment: i've seen tutorials for making DIY material out of plastic grocery bags by "welding" them together. the person would flatten out the bags on the fold/seam lines. take a ruler and draw a line straight across the top right where the handles attach and straight across the bottom almost right on the edge. then cut up one of the side seam/edges. now you'll have a flat long piece. do the same to about however many layers you want; the more the stronger. then the person setup their ironing board, wax paper, lined up the layers of prepped grocery bags, another layer of wax paper and ironed away. tada! and if there's a cool logo from a bag, cut it out and put it where you want it, once again sandwich with wax paper, iron, tada! :D - very sewable material in the end too. once made a messenger bag!~ :O :D
Jan 12, 2011. 9:21 AMthebigguy62 says:
I checked out this instructable, very cool. Girlfriend wanted to go to the beauty supply store yesterday, wandered in after her, on the way out I noticed a pile of flat irons, the type folks use to straighten their hair with. The cost was way too much for me to consider experimenting with, $50 to $100, but some of them have variable temperature controls, from 200 to 400 degrees. Seems to me it'd be well suited for what y'all are trying to do. If I should stumble upon one in a thrift shop, I'll go mug a kid for their drinks and try it out.
Chris
Aug 15, 2010. 9:46 AMsclausson says:
I have a Mini Iron made by Clover Needlecraft, Inc. Its ironing surface measures 1" x 1 3/8" . It is used for quilting and appliqueing. It has a 9" handle. I am going to test it on some Capri Sun and other foil lined packaging.
Jun 24, 2010. 2:34 PMkroekele says:
I've seen a miniature iron used in quilting and craft work at JoAnn's that might work. It looks reminiscent of a soldering iron, but has various tips at least 2 of which might work. You can find it listed as "Clover® Mini Iron II & Assortment Tips". They sell for about $60, but JoAnn's offers coupons each week, or if luck is with you, perhaps find one at a yard sale. Nice job on the instructable. I'm going to try it.
Apr 17, 2010. 6:19 PMheathbar64 says:
 I too was inspired by that ible where he used a soldering iron to make pouches out of freezer bag. I didn't have much success with the soldering iron, so I tried using my Seal a Meal heat sealer(Yardsale find) it was a little too hot for the ziploc bags, but I had success when I plugged it into a heat controller for a soldering iron. the heat controllers are sold for use with leaded glass work, and I found mine where else but a yard sale.
Oct 31, 2009. 3:48 AMkill-a-watt says:
I've used an iron before.
Of course, I've been resealing MRE pouches, potato chip bags, and the like for forever. It's great to seal up stuff like cigarette lighters so they stay waterproof while hiking
I remember having to adjust the heat down slightly from the top of the range. I also put some newspaper down so I don't accidental seal it to the ironing board.
try google/youtube with seal mylar iron
Nov 1, 2009. 7:11 PMkill-a-watt says:
one of the vids on youtube had someone using a cheap aluminium level as the "anvil" below the bag. I suppose something made of the same thing and not as wide would work. I've got some scrap 3/16 plate aluminium around but it's not exactly an everyday object.
Nov 1, 2009. 7:57 AMroadlet_411 says:
I actually work with machines that fill pouches very similar to this.  We fill them with a powder, not a liquid, but the method for sealing has to be the same.  All that seals the pouches is a heated surface not much different from your method, just a larger contact area to seal one entire side with each contact of the heater.  Depending on the general thickness of the stock, I seal bags in the range of 280*F to 310*F.  Heating long enough is just as important as heating too long or too hot.  You don't want delamination to occur at your seams, as this will cause the laminate to pull away from the foil and make a potentially weak and leaky seal.  Hope that's useful for you.
Oct 30, 2009. 8:11 PMZaphod Beeblebrox says:
join my group!
Oct 31, 2009. 3:32 PMCameronSS says:
Umm...Spam much?
Oct 31, 2009. 5:16 PMZaphod Beeblebrox says:
well lok at his name just trying to get members............do u like dr. pepper?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:DrPeper
Just your typical Evil Mad Scientist, constantly thinking of new inventions to subjugate the world with! I'm big on hydroponics, electronics, and small portable nuclear fusion power plants. I just g...
more »
