3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Welding plastic bags
Plastic bags can be welded together with a soldering iron. The resulting seam is strong and water resistant. This is a very useful technique for making kites.
Step 1Tools
Tools
You need some oven paper and a soldering iron.
I use a soldering iron with a flat tip and temperature control.
42 comments
1-40 of 42next »
Nov 12, 2011. 5:02 AMEngineerJakit says:
Just now finished an attempt at making some tubing, and its a good first try! I only used a cut section of one bag wrapped around a paper stick with a layer of parchment inbetween the plastic. So far, its like a fragile drinking straw with a bunch of small holes in it.
next time, im making it thicker and not applying as much heat. In this case for flexible tubing, possibly, too much heat will make it too stiff and hard.
Nov 14, 2010. 5:37 PMstudleylee says:
silicone.
Sep 6, 2008. 2:04 PMcasey321b says:
can you use a wood burning tool
Sep 10, 2010. 6:43 AMseabee890 says:
i would think,that if you had a wood burning tool( they are bigger yes?) a thin thin metal cutting blade and some tinkering would allow you to place a roller into the gap at the tip of a wood tool.
Feb 26, 2009. 9:59 PMraimen says:
pretty much the same thing, you prob. could.
Jul 7, 2010. 6:56 PMSHIFT! says:
Wow, this is awesome! Thanks so much for your instructable, this is really going to help when I build a garbage bag blimp!
Sep 18, 2009. 6:19 AMflying texan says:
is "oven" paper the same thing as wax paper?
Feb 21, 2010. 2:32 PMSuzanne in Orting says:
In this context, I would think that "oven paper" would be the same as parchment paper. The difference is that parchment paper is coated with a thin layer of silicon and can withstand the heat of the oven.  Waxed paper would melt.
Suzanne in Orting, WA
Sep 18, 2009. 6:50 AMflying texan says:
an idea just popped! this can be used to extend 2 liter bottles, or can it? submarines any one? or 2 liter-bottle long boat, or better bottle rocket! This plastic welding technique will be perfect for building an inflatable tent that can stay inflated with a computer cooling fan and 9v battery.
Jun 22, 2009. 7:37 PMprestonm says:
Could I use the tip of a clothing iron???
Jul 14, 2009. 10:44 AMurbanfreespirit says:
yes you could i always use an iron though you have to be quite careful
Apr 21, 2009. 5:25 AMservant74 says:
Years ago I had a soldering iron that had a teflon coated 'wheel' that replaced the tip (yes, it rolled). It was designed just for this kind of use. ... I wish I knew where I stashed it now!
Jan 23, 2009. 7:52 PMzipperboy says:
Thanks for the excellent lesson. I happen to have some baking paper already. Was using if for cooking now I can branch out. zipperboy
Dec 12, 2008. 5:56 AMdebutler says:
Kids in my class are using this technique to build hot air balloons. I've found that the scrap top paper from iron on transfer works like the oven paper and we are using the end of a hi-temp glue gun (new and never used with glue yet)to fuse the plastic sheets. They also have to make a "basket" for an egg to travel in their balloon and return safely to earth. They are having a blast and designing some really cool stuff. Thanks for the good ideas folks.
Nov 21, 2008. 3:38 PMm0d says:
This works great, thanks! I'm using it to weld 2mm plastic drop cloth with a generic 25W soldering iron and the oven paper. The seams are strong and very difficult to screw up, probably because of how thin this material is.
Mar 27, 2006. 6:52 PMcolin says:
This is a nice technique. What temperature are you using for your soldering iron? Also, what happens if you don't use the oven paper? Does it coat the soldering iron tip with nasty melted plastic?
Apr 1, 2008. 8:35 PMursus57 says:
I have seamed plastic by putting two pieces together, between two very flat pieces of wood. Use portable torch to lightly melt the plastic. Stick the ends out around a quarter inch beyond the wood. The seam is a little thick. A portable plastic sealer, like those used for sealing snack bags might work as well.
Oct 4, 2008. 6:21 PMstasterisk says:
Melting point of LDPE is 248 deg. F, you don't need to go above that. I just melted a bunch of bags in a pot on my stove. Colin, yes the bags get goopy and if you continue to apply heat, burn and smoke. I don't recommend attempting to make liquid LDPE in your home kitchen. If you do, use the maximum of ventilation.
Jan 28, 2008. 5:32 PMUnkat says:
If you don't have a soldering iron or wax paper, you can use a clothing iron for heat and thin cloth to protect the iron from the plastic.
Jan 8, 2008. 9:17 PMLego man says:
Can I site you for my next plastic instructable?
May 27, 2007. 4:21 PMKilla-X says:
I don't have any Oven paper. So I did a test on a lunch bag.
http://img175.imageshack.us/my.php?image=yayzp0.jpg
The thing I used (was harder due to no transparent) Foil. Yup, Normle Foil found in most houses. And I used a High-Temperature glue gun, and ran the nossle on the foil.
Feb 2, 2007. 9:54 PMgowithflo says:
Hey Aleksi, thanks for this. I was able to teach an inflatables Class in Haiti where every student got their own soldering iron + sandpaper kit, it worked like a charm.
Jan 2, 2007. 1:42 PMhannahb says:
i'm also an artist, this is a useful brainstorm page. you might also be interested in learning about the invention of the standard balloon for your own invention process.
http://science.enotes.com/how-products-encyclopedia/balloon
i am wondering if a wood burning tool will work as well as the iron mentioned above. if it melts plastic...i don't see why not.
Mar 27, 2006. 6:16 PMmycroftxxx says:
What kind of plastic bag are you joining? Can you add that to the title or make it a keyword?
Oct 23, 2006. 11:32 PMShane Johnston says:
Unfortunately mylar is not a material that can be heat welded.... I learned this the hard way upon spending countless hours attempting to make it air tight for an inflatable structure I was working on. Mylar is infact a thermoset. It's a really cool material none the less. In case you're curious. I ended up making the structure from PVC discharge tubing which is heat weldable and is inflatable to 60psi. The mylar (since I had a 50ft roll of 4mil and about 20 space blankets) became the skin.
Oct 27, 2006. 9:50 AMDawnT says:
Hi this technique sounds perfect for what i am trying to create! for my degree show i was wanting to use inflatable black birds. Do you think i could achieve the bird shape using this method? how to fill the shapes with helium do you need to add some sort of device to the balloon? cheers Dawn x
May 6, 2006. 7:52 AMCanibul says:
very interesting. I am putting together aerial photography setup, and need to be able to construct my own design helium blimp. Have all the camera, pan and tilt, video and control links already, and am now researching the blimp aspects of it. I want to build something similar to this blimp, but a shape of my own design.
Sep 23, 2006. 3:50 PMpennyd says:
Did you get anywhere with this project?I am interested in doing thesame thing.
Aug 28, 2006. 11:05 AMK-Menso says:
Canibul: I'd really like to build a small blimp to carry a Canon S1-IS (offhand, I'd guess it weighs a pound or less). I live next to an extensive marsh and hope to photograph wildlife from the air. I would appreciate any information you can provide. thanks!
Jul 26, 2006. 2:09 AMHaukilainen says:
Hi Aleksi, hey, this is a great idea! Recently I'm working on inflatables for my design diploma and I thoungt about something like that too. Do you have other expierenence on this topic, or what have you realized so far? cheers from BErlin, Germany, Flo
Apr 2, 2006. 4:14 PMehmbee says:
For sealing, you can use either the old Dazey "Seal A Meal" units-I found one at my local thrift for about four bucks. The only downside is it only will weld a section about eight inches. However, I also got a close look at my crock pot when it failed-there is a big wire inside them that wraps around the crock and heats up to keep the crock warm-you may be able to make a larger unit this way, or a combination welder/foam cutter with one. Again, found at the thrift for cheap. the Vacuum sealer units have a similar heated wire set up. Just some things to try or look at.
Apr 1, 2006. 2:30 PMWonderWheeler says:
This would be a great technique for making solar hot air balloons. If it will handle very thin plastic, such as that used in bags are used to package dry cleaned clothes. In the late '80's I was part of a group that designed and launched a passive solar hot air balloon. It dissapeared from sight within a few minutes and kept rising. If I remember correctly, the tape used to hold the segments of plastic together weighed about a third the weight of the balloon. The lighter a balloon, the smaller it could be made and still fly!
Mar 30, 2006. 4:03 AMslands10 says:
Do you think this technique could be applied to more rubber-like materials, which would normally be under pressure e.g. bicycle inner tube, inflatable RIB or dingy etc... Would the difference in material cause a poor join?
Mar 30, 2006. 6:10 AMslands10 says:
Magic, thanks for that, will be an interesting read : )
Mar 29, 2006. 6:03 PMelemenoh says:
Incredible technique!
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:Aleksi
