Introduction: How to #2 - Use LTC3780
This is a Buck Boost converter, which is a kind of high efficient power supply module with Constant voltage, constant current, under-voltage protection.
What is Buck Converter ?
It can step down the voltage
What is boost converter ?
It can step up the voltage
And This LTC3780 is Buck boost converter !
If you want to watch the video Click Here
And do check out my channel Click Here
Step 1: What Are These Pots ?
Far right one is for Under voltage protection (VV) and it is mostly used for Solar Charging
What does it mean ?
The device can monitor a DC-DC output voltage and quickly disconnect the power source from the DC-DC input load when an overvoltage condition occurs. A power-OK output signals when the DC-DC input voltage falls below an adjustable threshold.
Center one is for Constant Current ( CC)
What does it mean ?
A constant current is that does not change its intensity with time.
Left one is for Constant Voltage ( CV )
What does it mean ?
Same as CC does not change over time
Step 2: How Much Power Can It Handle ? and Efficiency ?
It depends on the board the one which I have used can handle Up to 130W
But after 80W it needs to increase the Heat Dissipation
And
The sweet spot for the efficiency is 98% at 12V
Step 3: Lets Power It Up !
I had a bunch of LED's soldered in parallel
After powering it up I have to say it worked like charm and I was able to control the voltage and current to change the intensity of the LED's
Step 4: Ending Notes
From where I got mine ?
Gearbest - Click Here
LTC3780 - Click Here
Volt Amp Display - Click Here
Shipping Time ?
It took 2 weeks for me to reach India
Packaging ?
Excellent Static proof bags with bubble wrap in it
Note - In the Next Instructables And video I am going the built a power Supply out of it !
So For updates you can check my Youtube Channel, Facebook And Instagram
Hope you like this Instructables
Happy Making !
