3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
What to do with your last match.
Seeing the instructables on fuses I thought I will make a similar one with just a length of string.This 'Fuse' took me 6 seconds to make.
Note this is not really a fuse.I'm only using the term fuse as I don't have a better way of referring to it
This is useful if you want to light several things like Cigarettes , fireworks and other stuff but you only have one match to do it all. I have attached a video to show how easy it is. This fuse is very safe and can burn for a long time but the cons is that it doesn't produce a enough energy for lighting bigger stuff (like charcoal ).
Step 1Light your string.
Light your string.
Really all you need to do is light your string and kill the fire by shooting it with your finger or blowing it out(as shown in the video).
Disclaimer:Do this at your own risk.(not that it's a risky process)
37 comments
Aug 21, 2009. 2:10 PMAbundantGeekery says:
If you have a box of matches you can cut off all the heads, grind them up and dissolve in water. Then soak the string in the solution and let it dry. That's how you can make an actual fuse. (Not sure if a box is enough or too many or what ever, I am just estimating at 1 box.
Jul 6, 2010. 6:29 PMtoogers says:
DO NOT DO THIS WITH STRIKE-ANYWHERE! THE CHEMICALS WILL COMBINE AND START A FIRE
Aug 21, 2009. 2:11 PMAbundantGeekery says:
Edit: This is a fuse not a punk.
Apr 27, 2010. 2:44 AMnutsandbolts_64 says:
 Just soak the string in gasoline and.... better yet: spread gasoline liberally on surface and light with match so you can light up more strings which will light up more gasoline and.... nvm
Apr 26, 2010. 2:46 PMRobot Lover says:
I would light a candle
Jul 16, 2009. 7:41 PMBriguy9 says:
I'm really sorry, no offense, but this isn't an instructable.
Nov 8, 2009. 7:25 AMColonel88 says:
Should I give him a FAIL sticker then?
May 10, 2009. 4:00 PMbaneat says:
You buy a lighter, and forget this ever happened.
Jul 8, 2008. 5:07 PMcodongolev says:
and what is this supposed to do?
Feb 20, 2009. 3:43 PMabsolute zero says:
i gotta solution for lighting bigger things. light ure buddys shirt on fire an tell him to lay on it
Jul 10, 2008. 7:13 AMcodongolev says:
hm.... so more an idea, than an instructional.
Feb 20, 2009. 9:35 PMBenH says:
Oh, you could probably make that into an instructable.
Jul 15, 2008. 8:12 PMA good name says:
More than an idea, less than an instructable. So you're saying that it's a candle? Lol.
Nov 3, 2008. 12:41 PMThelonelysandwitch says:
these are called punks. you can also use those fragrance sticks. p.s. you get punks for free at the fireworks store
Jan 2, 2009. 4:47 PMPlasmana says:
The cost money in the UK....
Jan 2, 2009. 5:44 PMThelonelysandwitch says:
Jan 24, 2007. 5:51 PMDrumboy410 says:
this is called a "Punk" and is often used to light multiple fireworks with one match. (Just to clarify)
Jun 12, 2007. 5:39 PM!Andrew_Modder! says:
an insents stick is better :-)
Jan 2, 2009. 4:48 PMPlasmana says:
yeah, it smells nice too!
Nov 4, 2008. 1:51 PMwilsonater says:
i don't mean to be mean or anything but... i think you should probably consider whether a lot of people would have already thought of what you re saying before you waste time creating an instructable about it. essentially, this is just lighting the end of a bit of string... everyone knows how to do that.
Sep 29, 2008. 2:27 PMmusic is my lfe2 says:
its just n ember but it works
Aug 4, 2008. 12:42 AMryanohal says:
thats just a string isnt it
Aug 5, 2007. 10:29 PMthatkidej says:
I think being a little more specific on what type of string to use is one way to improve this instructable.. But I just don't get the point in general, there are easier ways. Like people said, incense sticks work good. Hell, twigs from outside would work. Even without a match, I'm sure you have a stove. What about a candle? The possibilities are endless..
Feb 24, 2008. 5:35 PMwowuser3894 says:
thank u very much but fyi butcher string wiil work for a while
Sep 3, 2007. 7:32 PMduct tape says:
Cotton string. Also, if you give it a light coating of sulfur it will work better.
Jul 30, 2007. 8:29 AM$T.ars3nic says:
Punk is a stick of compressed sawdust that burns extremely slow, used for igniting consumer fireworks.
Jul 2, 2007. 5:54 AMteh_pyroazn says:
soak it in meth spirits then ignite!!!! MUHAHHAHAHA!!!! lame but it burns! thats what counts!
Jan 24, 2007. 8:57 PMwEiRd LOAD says:
try some parafin wax and insertthe string in a small brass tube with one end pinched havent tried it may get hot get out the electrical tape:)
Jan 20, 2007. 6:55 PMthermitemaster says:
wtf its a piece of string. not that great for fuses.
Jan 21, 2007. 7:07 AMJezza Bear says:
Sorry, I was helping and showing another use for your idea. An enhancement as a fire starter or heat store is to use bound cord, or cord in a sheath, they are used as they are more difficult to put out in high wind.:-)
Jan 20, 2007. 4:50 PMJezza Bear says:
This method is used by farmers to scare crows. In UK terminology a "crow scarer" is a small firework or banger. The farmer takes a piece of cord or thick string and weaves the fuse of the crow scarer into the cord, very simplyby pulling the thread apart and inserting it. They will do this a different distances apart , hangs it from a tree branch, lights the cord as you have and it smoulders, gets to fuse of scarer sets it off, BANG, smoulders, BANG ad nauseum. Useful method, but your string may need to bethicker as I have seen this thickness blow out easily.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Oorspronklikheid
