WhatsApp on Raspberry Pi
257,968
257
135
Published
Introduction: WhatsApp on Raspberry Pi
In this tutorial we will see how to use WhatsApp with Raspberry Pi.
We will use the Yowsup library we had already used in these tutorials: WhatsApp message from Phidgets SBC , Phidgets WhatsApp - ask the status of your sensors.
These days the library has been completely rewritten and improved, so we will see how to install it and use it.
Yowsup is a python library that allows you to login and use the WhatsApp service and provides you with all capabilities of an official WhatsApp client, allowing you to create a full-fledged custom WhatsApp client.
You need:
a Raspberry Pi B or B+, with the latest version of Raspbian, or our MIcroSD Card 8GB Class 10 Raspbian preinstalled.
Step 1: Installation
Update the packages with
sudo apt-get update
sudo apt-get upgrade
Update firmware
sudo rpi-update
Prepare the system with the necessary components to Yowsup
sudo apt-get install python-dateutil
sudo apt-get install python-setuptools
sudo apt-get install python-dev
sudo apt-get install libevent-dev
sudo apt-get install ncurses-dev
Download the library with the command
git clone git://github.com/tgalal/yowsup.git
navigate to the folder
cd yowsup
and install the library with the command
sudo python setup.py install
Step 2: Registration
After installing the library we have to register the device to use WhatsApp. Yowsup comes with a cross platform command-line frontend called yowsup-cli. It provides you with the options of registration, and provides a few demos such as a command line client.
WhatsApp registration involves 2 steps. First you need to request a registration code. And then you resume the registration with code you got.
Request a code with command
python yowsup-cli registration --requestcode sms --phone 39xxxxxxxxxx --cc 39 --mcc 222 --mnc 10
Replace with your data ,
cc is your country code in this example 39 is for Italy,
mcc is Mobile Country Code check your here
mnc is Mobile Network Code check your here
You should receive on your phone a sms message with a code like xxx-xxx
Send a message to request registration with this command, (replace xxx-xxx with code you received)
python yowsup-cli registration --register xxx-xxx --phone 39xxxxxxxxxx --cc 39
If all goes well, we should get a message like this
status: ok
  kind: free
  pw: xxxxxxxxxxxxxxxxxx=
  price: € 0,89
  price_expiration: 1416553637
  currency: EUR
  cost: 0.89
  expiration: 1445241022
  login: 39xxxxxxxxxxx
  type: existing
Warning
WhatsApp requires the registration of a number, and with that number you can use WhatsApp on only one device at a time, so it is preferable to use a new number.
WhatsApp can be used on one device at a time and if you will make many attempts to register the number, it could be banned. We recommend you using Telegram, see our tutorial
Step 3: Utilization
Create a file to save your credentials
sudo nano /home/pi/yowsup/config
with this content
## Actual config starts below ##
  cc=39 #if not specified it will be autodetected
  phone=39xxxxxxxxxx
  password=xxxxxxxxxxxxxxx=
Ok, we're ready for the test, Yowsup has a demo application in /home/pi/yowsup/yowsup/demos
Navigate to yowsup folder
cd /home/pi/yowsup
Start yowsup-cli demos with the command
yowsup-cli demos --yowsup --config config
You can see Yowsup prompt
If type "/help" you can see all available commands
First use the '/L' command for login; to send a message type
/message send 39xxxxxxxxxx "This is a message sent from Raspberry Pi"
replace xxx with the recipient number
If you respond with a message it will be displayed on Raspberry.
The possibilities of use are endless, for example you could use
WhatsApp to send messages in the home automation system seen in the tutorial Home Automation Raspberry and Phidgets part 2 or Home Automation Raspberry and Phidgets part 3
Follow us on social to stay informed.
www.emmeshop.eu
    • Clocks Contest
      Clocks Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    Hello, I did all the steps of the tutorial ...... but it worked only once, that is, I got to send the message to the destination number, but I tried to send another message a second time, but I got the Authorization error denied, and I tried to register the number again and it turned out that the number was blocked.
    It is the second number that blocks :)
    Please help me.
    regards
    135 Comments
    I have receving the registration errors wat to do to recover it
    i am getting this during registration:
    INFO:yowsup.common.http.warequest:{"status":"fail","reason":"old_version"}
    i m getting the same error aswell. if u found the solution plz do tell me
    I'm have the same problem.
    HELP PLEASE
    edit yowsup/env/env_android.py and change:
    _MD5_CLASSES to 1I2weuZmVg+uL50+HXeSJw==
    and
    _VERSION to 2.16.328
    on yowsup/env/env.py
    change:
    DEFAULT to android
    Realice los cambios en los archivos que sugieres pero al ejecutar el comando de yowsup para el request code, me da el siguiente error:
    yowsup-cli v2.0.15
    yowsup v2.5.7
    Copyright (c) 2012-2016 Tarek Galal
    http://www.openwhatsapp.org
    This software is provided free of charge. Copying and redistribution is
    encouraged.
    If you appreciate this software and you would like to support future
    development please consider donating:
    http://openwhatsapp.org/yowsup/donate
    Traceback (most recent call last):
    File "yowsup-cli", line 368, in <module>
    if not parser.process():
    File "yowsup-cli", line 189, in process
    self.handleRequestCode(self.args["requestcode"], config)
    File "yowsup-cli", line 206, in handleRequestCode
    method
    File "/home/pi/yowsup/yowsup/registration/coderequest.py", line 41, in __init__
    self.addParam("token", YowsupEnv.getCurrent().getToken(p_in))
    File "/home/pi/yowsup/yowsup/env/env_android.py", line 55, in getToken
    clsDecoded = base64.b64decode(self.__class__._MD5_CLASSES)
    File "/usr/lib/python2.7/base64.py", line 78, in b64decode
    raise TypeError(msg)
    TypeError: Incorrect padding
    Agradeceria mucho su ayuda!
    Thank you very much
    Hi, Ihave problem with Yowsup. Anyone can help me to solve it? Regards
    status: fail
    reason: old_version
    login: 628xxxxxxxx
    pi@raspberrypi:~/yowsup $ ./setup.py build
    running build
    running build_py
    running egg_info
    writing requirements to yowsup2.egg-info/requires.txt
    error: [Errno 13] Permission denied: 'yowsup2.egg-info/requires.txt'
    I'm having a problem with this code:
    If I wrote that in my terminal. The output said that it is failed because of an old_version. What can I do?
    I'm confuse. You don't need a simcard for this matter ? how?
    yes you do, in your phone, to receive the registration code
    Please help. Took me hours to start sending messages. Now I get this.
    [connected]:/message send 8687895253 "Hello world!"
    [connected]:Traceback (most recent call last):
    File "/usr/local/bin/yowsup-cli", line 4, in <module>
    __import__('pkg_resources').run_script('yowsup2==2.5.2', 'yowsup-cli')
    File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 534, in run_script
    self.require(requires)[0].run_script(script_name, ns)
    File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 1438, in run_script
    execfile(script_filename, namespace, namespace)
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/EGG-INFO/scripts/yowsup-cli", line 368, in <module>
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/EGG-INFO/scripts/yowsup-cli", line 268, in process
    self.startCmdline()
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/EGG-INFO/scripts/yowsup-cli", line 297, in startCmdline
    stack.start()
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/demos/cli/stack.py", line 26, in start
    self.stack.loop(timeout = 0.5, discrete = 0.5)
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/stacks/yowstack.py", line 188, in loop
    asyncore.loop(*args, **kwargs)
    File "/usr/lib/python2.7/asyncore.py", line 216, in loop
    poll_fun(timeout, map)
    File "/usr/lib/python2.7/asyncore.py", line 156, in poll
    read(obj)
    File "/usr/lib/python2.7/asyncore.py", line 87, in read
    obj.handle_error()
    File "/usr/lib/python2.7/asyncore.py", line 83, in read
    obj.handle_read_event()
    File "/usr/lib/python2.7/asyncore.py", line 449, in handle_read_event
    self.handle_read()
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/layers/network/layer.py", line 102, in handle_read
    self.receive(data)
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/layers/network/layer.py", line 110, in receive
    self.toUpper(data)
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/layers/__init__.py", line 79, in toUpper
    self.__upper.receive(data)
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/layers/stanzaregulator/layer.py", line 29, in receive
    self.processReceived()
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/layers/stanzaregulator/layer.py", line 49, in processReceived
    self.toUpper(oneMessageData)
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/layers/auth/layer_crypt.py", line 65, in receive
    self.toUpper(payload)
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/layers/coder/layer.py", line 35, in receive
    self.toUpper(node)
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/layers/logger/layer.py", line 14, in receive
    self.toUpper(data)
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/layers/axolotl/layer_control.py", line 44, in receive
    self.toUpper(protocolTreeNode)
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/layers/__init__.py", line 194, in receive
    s.receive(data)
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/layers/axolotl/layer_send.py", line 64, in receive
    if not self.processIqRegistry(protocolTreeNode):
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/layers/__init__.py", line 161, in processIqRegistry
    successClbk(protocolTreeNode, originalIq)
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/layers/axolotl/layer_base.py", line 51, in onSuccess
    entity = ResultGetKeysIqProtocolEntity.fromProtocolTreeNode(resultNode)
    File "/usr/local/lib/python2.7/dist-packages/yowsup2-2.5.2-py2.7.egg/yowsup/layers/axolotl/protocolentities/iq_keys_get_result.py", line 88, in fromProtocolTreeNode
    preKeyId = ResultGetKeysIqProtocolEntity._bytesToInt(preKeyNode.getChild("id").getData())
    AttributeError: 'NoneType' object has no attribute 'getChild'
    hi, i have a problem, when i try to install the library with the command:
    on the end of installation i have this error:
    error: Installed distribution six 1.8.0 conflicts with requirement six>=1.9
    anyone have a idea of the solution, please help me
    please use sudo pip install --upgrade six :)
    hello.. what should we need to give in the password field of this section.
    phone=39xxxxxxxxxx
    Hi all. What is the latest solution for the issue during registration:
    status: fail
    reason: old_version
    Any clues, will be very appreciated.
    e
    Source: https://github.com/tgalal/yowsup/issues/1920
    After reading other posts, I ran
    ./setup.py build
    and then registered a different number. It worked! Sending and receiving messages also works.
    In summary, I used these parameters in env_s40.py.
        _VERSION = "2.16.11"
    _TOKEN_STRING = "PdA2DJyKoUrwLw1Bg6EIhzh502dF9noR9uFCllGk1478194306452{phone}"
    and I registered an Israeli number, so the command line arguments were not as shown in
    my previous post.
