Wheel Toy
Introduction: Wheel Toy
The wheel toy is made of waste cups, PVC pipes and powered by rubber bands. As you will wind the stick at the right end of the toy and launch it, the teddy wheels will start moving on its path!!!!!!!
Step 1: Materials
Couple of plastic cups with the base diameter of almost 4 - 5 cm
A PVC pipe of length approximately 8 - 10 cm
Candle stick
Lean stick of about 15 cm length
Two sheets of magazine paper
40 cm of aluminium wire
Thick thread
A small sized teddy bear approximately of height 4 - 5 cm
Step 2: Prepare Wheels & Axle
Cut the base of the cups, leaving a base width of 1 cm to make it the tyres for the toy
Make a hole at the center of the cup bases, with the help of a nail. Nail can be heated up to make it simpler
Cut the PVC pipe to the required length and make the ends smoother and even with salt paper. This makes the axle of the toy
Use spray paints to make it colorful
Use a strong glue to stick the cup bases and the axle together. Make sure to stick the PVC pipe at the center of the cup bases
Cut 1.5 cm from the candle stick, with the help of a heated nail, put a hole at the center of it. This wax piece helps as a lubricant while winding the stick and to hold the teddy's steering bar
Step 3: Inserting the Rubber Band
Use package rubber bands that has high elasticity and can retain the shape when released from the highest stretch.
If the length of the band is more than 4 cm then fold it twice or thrice to have the length less than our wheel and axle length
Bend a 20 cm aluminium wire and have the rubber band in it. It will make the process easier
Insert the aluminium wire as shown in the figure
Lock with a small stick at one end and glue the stick with the cup base
At the other end insert the wax piece and lock with the long stick
Step 4: Steering Bars for Teddy Bear
Wind the magazine paper as tight as possible and glue it at the ends. Make 2 such sticks and insert into one another with the glue
Use spray paint to make it colorful
Insert the aluminium wire inside the paper stick and bend the stick at the two sides leaving the center width of one cm more than the overall length of the wheel and axle structure
Make it a small hook at one end and leave a 3 cm wire at the other end
At the small hook side, tie a thick thread. put multiple knots repeatedly at the other end of the thread. The overall length of the thread should be 1 - 2 cm. Insert the knotted side of the thread in to the cup base
The other side of the stick, roll the wire over the wax
Make sure the sticks are not touching the wheels
Please refer pictures for reference
Step 5: Hook the Teddy
Bend the aluminium wire over the teddy and hook it with the stick
Now the Wheel Toy is ready
Step 6: Running the Wheel Toy
Wind the stick till you feel the tense of the rubber band and place it on the floor
Don't forget to vote me if you like the post
Thanks for reading the instructable
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Epilog Challenge 9
      Epilog Challenge 9
