What is a Question?
Questions are a super-easy way to get answers from the Instructables community. Learn how to build, do, or make anything! You just ask a question and the community will provide answers. You choose the best answer!
Submit a Forum Topic! The forums are the place to ask questions, share a cool project from another site, find collaborators for your latest project, or discuss anything of interest to the Instructables community.
Do you have a lot of images to upload?
If you prefer to upload your images before you submit, then this is for you.
Remember to tag them so they will be easier for you to find when you are viewing your library.
You can also upload images when you are creating your posts.
Did you find a bug or have a suggestion for us?
We appreciate all the help our users give us in tracking down bugs and making the site better for everyone.
PhotosPhotos
Great Instructable! I've only trued a couple wheels before, but it was from reading a written description of the steps. This video makes it a lot clearer. Great job!
Ditto. I usually do this with the wheels mounted and often forgo the height truing and only do the sides. With the idea of loosing all the spokes a half turn or maybe to the starting point of where they all sound the same will save me from having to true every couple of weeks. The oil idea is also a winner since I usually have to do a half turn to get the spoke and nipple to pop and then backup a half turn or whatever to do the actual adjustment. I'm now thinking of converting an old defunct frame into a brand new stand.
The height truing for me usually is able to be counteracted by how the tire is balanced on the rim, because I've noticed that sometimes the tire will be off-centre by millimetres once mounted, even if the bead looks to be evenly-seated all around, so I often use that to my advantage, and counter-act the rim being slightly off-centre...
Hi, good video i got a question, i have a bmx and my backwheel is warped so it rubs against the frame. im in australia how much do the tuning things cost? should i bother trying to fix it?
u just need a spoke wrench and google how to do it, its not insanly hard jst dont over tighten the spokes. if u dont have a spoke wrench jst put a notch in a flat head screw driver with an angle grinder or cut off tool. however sometimes ur rim is just to warped for the spokes to even things up so u may jst need a new rim. good luck though
When I true wheels, I will often clamp the lock-nut for the bearings into a vise, so that a bent axle is less of an issue, although, it usually has no affect on the trueness of the wheel, just how it aligns with the brakes, and how it aligns with the front wheel (in the case of the rear wheel) Alignment with the front wheel can be adjusted by loosening off nuts and tightening them until it's aligned...
Awesome! i followed your guide and used my brakes as the guides and it's trued like a charm! ain't no bike shop getting my monies for something i can do myself! Thanks again!
Thank you for posting this video. One of my trike wheels, which is supported on only one side, is a little warped. Would it be best to just true it on the trike?
it's hard for me to figure out which way the wheel moves laterally when tightening or loosening the spokes - it would have been useful to me to see a couple of arrows in the picture of the wheel showing the spoke tightening direction and resulting lateral movement of wheel.
One thing to remember: Wipe the wheel clean so that the oil does not get on the braking surfaces, or on the innertube itself. Also, if there is ANY separation of the rim seam, or ANY crack is noticed, do not bother to true it, discard the rim. Deflating the tire is not really necessary though, in my experience. As a further note, if you are loosening spokes because tension seems too high, be sure that upon final inspection that the wheel will not deflect more than 1mm @ 8lbs of lateral force. an alternate method is to squeeze adjacent spokes as if you were trying to crush a beer can. The spokes should barely deflect with moderate force. Spoke "note" (as mentioned in the video) should resemble an "A" note on 20" wheels, no lower than a "C" note on 24" wheels, about a "C" note on 26" wheels, and no higher than a "D" note on 27"/700C wheels. A great way to avoid spoke breakage from truing is to apply anti-sieze to the spoke threads when building the wheel, or rub the tip of a #2 pencil on the threads prior to assembly. If you encounter a sticky spoke nipple, try moving back and forth in both directions to get it free. Alternately, use "PBlaster" penetrating oil on it and rap the spoke nipple with a sharp, metallic vibration a few times. If it will not let go, and you'd rather save the spoke than the nipple, use vice-grips and put some crushing force on it....you'll ruin the nipple, but save the spoke. Recommended oils for spoke lubrication is "liquid wrench", or clean kerosene (remember not to let these contact the rim braking surface or the innertube).
Very well done. I always had hiccups when it came to the roundness of the wheel. Lateral truing was no problem. My books always said to laterally true first. I'm going to try it this way next. +1
Thanks for all your enthusiast comments, I really appreciate them. As for the videos, I use Revver.com because I like the customization options and video quality, among other things. I use several of other video sharing networks but nothing is as good as Revver. Highly recommended.
Simple, clear, direct and very usable instructions. I knew the basics but never had it explained in this level of detail. I never thought of pre-lubricating the nipple. Awesome, thanks!!
you people should look into them
"worlds finest hand built wheels"
Video's quality is just great, everything is just awesome!
Nice job.
And by the way, what video format is this?
Well, what site did you upload these videos onto?
Like YouTube, or something. It's obviously not YouTube, so I was wondering what it is? It looks cool.
Did you make it?
