Wheelchair Attached Storage
2,142
6
7
Posted
Introduction: Wheelchair Attached Storage
This is my 11 year old, "Booger". She had a bout with SCFE, (https://secure.wikimedia.org/wikipedia/en/wiki/Slipped_capital_femoral_epiphysis) which landed her in a wheelchair for 3 months. These 3 months included Maker Faire NC, which we had been planning to attend for at least a couple months before this happened. Knowing we were still going to go, wheelchair be damned, we needed a way to carry the inevitable SWAG without piling it all on her lap or my back. Here is my solution. This is my first instructable, so be gentle... critical, but gentle!
Step 1: Convienience Items
Since the wheelchair was rented I couldn't affix any more permanent modifications, plus a permanent attachment of the rear mount basket would have rendered the chair unable to fold. After sewing her some tush cushion and adding a way for her to tote her water bottle, it was time to figure out how to attach a milk crate to the back of the chair.
Step 2: Found a Basket... Now What?
the old milk crate I "acquired" was a little too narrow to rest atop the kick stubs on the chair. After removing the rubber bumpers on the kick stubs, I found pre-drilled holes.
Step 3: Measure!
Measured the basket. it was 13 3/4 in x 15 3/8 in
Step 4: Gathering Supplies
We were in Lowe's and I saw these 2' sections of PVC for between $1.50 and $2 each and decided that would be the best thing to build a removable carrier for our "basket".  I got 5 sections of 1/2" PVC and 4 sections of 1". Not being an engineer and not really all that adept at math, I made rough guesstimates as to the lengths and used a power miter saw to cut the PVC to my guesstimates. I also picked up 2 1" to 1/2" 90 degree adapters, 4 1"X1/2" tees, 2 1/2"x1/2" tees and a 1/2"x1/2" cross. After my initial guesstimates were wrong, I remeasured and basically cut to fit. The final cuts were 2 2" sections of 1", 4 6" sections of 1", 6 7" sections of 1/2", and 2 6" sections of 1/2". My initial cyphering failed to include the adapters.
Step 5: Assembly
After I finally got it where I thought I wanted it size-wise, I press fitted it together. I decided against PVC cement, as I could disassemble it and use the parts again for future projects! Initially I attached it with 8 6" zip ties and only in the center cross bars of the crate and the carrier, but before we left, I added 8 12" zip ties around the perimeter, just to make sure.
Step 6: Attaching to the Chair
I used 1/4-20 carriage bolts, washers and Nylok nuts to attach the carrier to the chair. Unfortunately, Lil Bit, my other daughter, decided that they better served her uses elsewhere... I have yet to find out where! I did add some electrical tape to the kick stubs to tighten the fit of the carrier a little more to my liking.
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
7 Comments
Nice, I guess my solution would have been to hang an IKEA bag on the back handles.
Not nearly as Instructable worthy or fun for that matter! ;-)
TRUE!
Hope your Boog's alright now :-) Good instructable :-)
I like this. How was it to push? Were you hitting it with your shins much? I have a thought for an improvement useing this as the base but it may be unnessary if this works fine. This would work great on Zoo trips for the better half without haveing to lug everything on my back =}
It wasn't bad to push. I did have to be aware it was there and caught my shins a couple times. If it was used on a regular basis, you'd get used to it being there.
Ok thanks. What I'm thinking is to make a slideing type tray attached like you have it. I may need to think it thru better but thats the general idea.
I cyphered a couple of different deployments of it, but found the fixed position and sticking out a little bit worked best for me. Couldn't move it in any closer as it would have jammed it in her back, but a scaled down basket would be doable if it slid under the actual seat part. Good luck with any mods! Glad i could at least be (hopefully) a partial inspiration. Keep us posted on any build.
