Introduction: When You Can't Find Your Harmonica: Carrot Flute
I recommend viewing the short form video, printing the instructable for your work time, then viewing the long form video (so that you can see what I did).
Short form video.
Step 1: Gather Your Ingredients for the Flute
You will need:
A drill and bits to make a large and small hole. A 1/2" drill bit and a 15/64" bit worked for me.
Sharp knife
1 or more carrots
Cutting board
Long, narrow tools to take carrot debris out of the hole. E.g. skewer or chopstick.
Step 2: Cut the Leafy End Off of the Carrot.
Using the sharp knife, cut the carrot top off of the carrot. This provides a flat surface that you will drill into.
Step 3: Drill the Main Hole.
Using the 1/2" drill bit, drill a hole that starts at the flat surface of the carrot that you just made, and goes along the length of the carrot. I went about 1/3 of the way into the carrot.
Step 4: Clear the Hole of Debris.
Take out all of the carrot bits, as they will prevent the sound from being clear and sharp. Use a skewer, chopstick, the bit, or anything you can find that will fit down the hole. I used a pen.
Step 5: Make the Smaller Hole.
Hold the carrot in front of you with the carrot top side facing up. You will need to drill a hole, using the smaller bit, a bit down from the top of the carrot. I chose a spot that ended up being about an inch down the side. I've found that if you go too far down, the sound is not very good.
Step 6: Clearing the Debris... Continued.
You may want to blow down the various holes and tap the carrot on the cutting board to ensure the debris is all removed.
Step 7: Play Your Carrot Instrument.
Now you are ready to play! Have fun, make more, have each person play one and see what sounds you get!
Second Prize in the
Play With Your Food Contest
Musical Instruments Contest
