3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
When a Phillips is not a Phillips Plus So Much More!
Step 39Scroll™ Nuts & Screws
[[br]]Tamper resistant, releasable Scroll™ Nuts and Scroll™ Bolts are the ultimate security fixing. They offer a clever solution for those situations where you need an anti tamper fixing that can also be undone when the need arises. The Scroll™ Nut or Bolt is installed and removed with the aid of a special driver tool. The 1/2" drive security driver is cross drilled with a hole that allows it to be used with a 'T' bar or a standard socket drive set. The tool to match the Scroll™ Nuts and Bolts are registered to the owner adding additional security.
The special grooves cut into the outer surface of the scroll nut accommodate the special driver lugs in the recessed cup to allow the nut to be tightened or released. As a special manufacturing option, the scroll nut can also be made with just a drive groove, converting the nut into a one-way unit which performs in the same way as a shear nut. Sizes available in even numbers M6 to M12 and Tool Reference in even numbers SC6 to SC12.[[br]]
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:arcticpenguin
