3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
When a Phillips is not a Phillips Plus So Much More!
Step 88Tamper Pin TX security Screws
[[br]]Torx® is a registered trademark of Acument Intellectual Properties LLC, see Torx® Drive step. Tamper resistant Torx® screws feature a post in the center of the recess. This post will only fit into a tamper resistant Torx® bit. They are also referred to as Torx security drives, Torx security heads, Torx tamper resistant drives, Torx tamper resistant heads, star tamper resistant screw, Torx security drive screw, Torx security screw, Torx security tamper resistant screw
The Tamper Pin TX Security Screw as its name states has an internal pin within the 6-lobe socket (star drive) of the head, requiring a special insert bit or key wrench to insert and remove. This unique feature renders the Tamper Pin TX Screw tamper proof, reducing the risk of vandals or intruders tampering or undoing the screws. Due to the design of the Tamper Pin TX Security Screw it is suitable for higher torque applications and is "2 way".
Except for the pin, the Tamperproof Torx® heads are the same as the internal recess heads, with sizes including - TT-7, TT-8, TT-9, TT-10, TT-15, TT-20, TT-25, TT-27, TT-30.[[br]]
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:arcticpenguin
