Square Drive Screws and Drivers
These screw types have a "+" shaped recess on the head and are driven by a cross-head screwdriver, designed originally for use with mass-production mechanical screwing machines. There are a few other recessed drive screws presented that you also want to be aware.
So, why all the confusion? Why all the damaged screw heads and drivers? Why is this screw and driver thing so awkward? Read on and be amazed while I unravel the mystery of screw drives and present some you may have never seen.
For each screw drive type, from ancient Slot through to space-age Lox we present a quick view of the screw head, the drive name, a picture of the appropriate drive bit, followed by an explanation of the type. Also presented are the advantages and disadvantages of each drive type. Slot type are also included because that is where the screw began and a double slot becomes a cross drive, and the Robertson or square drive enter the story with recent combined Phillips/Square drives. The Allan, Spline, Torx etc drives are not included and maybe neither should the Uni-Screw, it is just so darn new and interesting.
This article contains a lot of information and pictures from the Internet. Maybe it will be the definitive guide with your help it could get close. If you disagree with any of the information or if I missed a related drive you know of, please let me know where I can validate the information. Misinformation, incorrect illustrations, screwed up usage of terms on the Internet and elsewhere is rampant and part of the problem created by so many drives.
First a little background:
A screw is really a shaft with a helical groove or thread formed on its surface. Its main uses are as a threaded fastener used to hold objects together, and as a simple machine used to translate torque into linear force. It can also be defined as an inclined plane wrapped around a shaft.
Every threaded fastener needs a way of turning it. Whether a wrench fits a hex-head bolt or a nut, or it may have a shaped and recessed hole into which a driver can be inserted.
Remove these ads by
Signing UpStep 1: Early Screws
Metal screws and nuts used to fasten two objects together first appeared in the fifteenth century.
In 1770, English instrument maker, Jesse Ramsden (1735-1800) invented the first satisfactory screw-cutting lathe. Ramsden inspired other inventors. In 1797, Englishmen, Henry Maudslay (1771-1831) invented a large screw-cutting lathe that made it possible to mass-produce accurately sized screws. In 1798, American David Wilkinson also invented machinery for the mass production of threaded metal screws.
The screw on the left (A) was handmade in the late 18th century. Note the flat spot on the shaft, the irregular threads, blunt tip and the off center slot. The screw in the center (B) is machine made around 1830. It has sharp, even threads, a cylindrical shape, blunt end and the slot is still off center. The screw on the right (C) is a modern gimlet screw, post 1848, with tapered shaft, even threads, pointed tip and centered slot.
Visit Our Store »
Go Pro Today »
Here is my LEAST favorite screw head: The screws that are designed to take either a Phillips #3 or Robertson (square) drive. Some of the new timber construction fasteners, such as Spax, and some of the common bronze wood screws use this "combination" drive. It is my experience that tools designed to do two (or more) things do neither well.
(I wrote a post at iFixit)
See this photo (big, more here) : http://guide-images.ifixit.net/igi/D3MMQfb6G3HMrtNk
They don't seem Phillips, may be JIS or Frearson.
What do you think?
Thanks!
As for Frearson, I've not knowingly seen them, but they seemed to be more a North American form of the JIS.
Being a screw head and not a tool bit it isn't easy to measure the angles of the blades to know for sure.
Thanks for the great question
So I think I will buy JIS screws.
Thanks again.
Please check my other "ible" titled "When Is A Phillips Not A Phillips Plus So Much More" (a follow-up to this project) which attempts to identify all or at least most screw driver types. There you will find other 5-Lobed screw drives, even a tamperproof version of this security bit.
Thank you
From your posting on 2010 February 11:
"I'm almost sure what you refer to as Eiki ISO screws were actually JIS-Type screws with ISO metric threads. Two ways of saying the same thing basically. Similar to if I'd call them Yuyama ISO screws."
From a fading memory, I think your statement is correct.
In about 1965 or thereabouts, the movement toward some standardization in metric fasteners was well under way, and the JIS (Japanese Industrial Standards) people were beginning to align themselves with most of the rest of the world in making fasteners that would be interchangeable with the same thread specifications. The DIN standards seem to be the ones that were most favored and were adopted as the ISO standards. As you mentioned, the main shift in the JIS screws was in the change from the previous JIS thread diameter and thread pitch to the now standard ISO specifications. This affected the smaller size fasteners the most, as far as the JIS screws were concerned. The more common sizes of 6 - 1.00, 8 - 1.25, and some others, were not affected.
One of the differences was in the 5mm diameter screw where the previous JIS Standard of 5mm diameter and 0.75mm thread pitch became the same as the DIN or ISO 5mm diameter and 0.8mm thread pitch.
This is where the distinction becomes important. At this point, to distinguish between the earlier JIS Thread Specification and the newer ISO Thread Specification, they added to the head of the fastener, or the side of the nut, the "dot" or "dimple" or small round recess to show that this is the new fastener, and not the older JIS Thread Specification. The form of the head of the fastener did not change; it is still the JIS head using the JIS tooling for installation and removal. Only the thread form or thread specification changed. This is the significance of the "dimple" on the head of the JIS fastener.
TA-125
Weld a piece of metal on it and just unscrew it using using your hands =D
~hope this helps someone
Secondly, in my dozen plus years as a camp ranger and caretaker, I have driven literally thousands upon thousands of these "Deck Mates" and they are my go-to screw, even though they are a bit pricier and I can only find them at Home Depot. I do find that even though they are marketed to be driven with standard philips bits, it has to be a very good bit to have with success with it. Standard square drives are no problem however. Stick with the matched Philips II bits with the ACR and you can't go wrong. Good thing they're included with a full box of screws. I've managed to shatter a few of them driving hard.
an easy way i bypassed it was i took my dremel and a cutting wheel and ground out the "bump" in the middle. Then it turned into a flathead.
Finally published it, waited way too long for a contest to enter it in and finally gave up the wait to share this.
Maybe it can reach fame through your many visits.
Enjoy!
I'd also like to know what is the most complete set of screw bits. ???
I've found these:
http://www.amazon.com/dp/B001OM1KNO?smid=AH1JDG368QYFS&tag=nextag-tools-tier2-delta-20&linkCode=asn
https://www.toolshopdirect.co.uk/item.php/store//c1/120/c2/966/sn/40128
But they are not complete
I'd like it to have the triangular, polydrive, one-way, uni-screw, mortorq, 5-node, Square tamperproof, Phillips Tamperproof and clutch.
I've also look at many different brands and I guess the only way to get them is purchasing each piece separately, but that's too expensive
You forgot the clutch
regards
