Step 10: JIS - Japanese Industrial Standard
Advantages and Disadvantages of JIS
Most people and companies outside of Japan have absolutely no idea what they are. With the similarity in appearance to the Frearson and the Phillips the screws are often damaged in removing and installing with the wrong tools. JIS tends not to camout like Philips. The JIS driver can be used on Phillips quite easily but not reciprically. Drivers are not easily available in North America, try your local RC Airplane hobby shop. Most RC Helicopters use JIS screws to mount the propeller. JIS-spec cross-head screws are generally marked with a single raised dot or an "X". JIS always fit Phillip fasteners, but because of slight design differences, Phillips drivers may not fit JIS fasteners. (unless the tip is ground down a bit).
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
(I wrote a post at iFixit)
See this photo (big, more here) : http://guide-images.ifixit.net/igi/D3MMQfb6G3HMrtNk
They don't seem Phillips, may be JIS or Frearson.
What do you think?
Thanks!
As for Frearson, I've not knowingly seen them, but they seemed to be more a North American form of the JIS.
Being a screw head and not a tool bit it isn't easy to measure the angles of the blades to know for sure.
Thanks for the great question
So I think I will buy JIS screws.
Thanks again.
From your posting on 2010 February 11:
"I'm almost sure what you refer to as Eiki ISO screws were actually JIS-Type screws with ISO metric threads. Two ways of saying the same thing basically. Similar to if I'd call them Yuyama ISO screws."
From a fading memory, I think your statement is correct.
In about 1965 or thereabouts, the movement toward some standardization in metric fasteners was well under way, and the JIS (Japanese Industrial Standards) people were beginning to align themselves with most of the rest of the world in making fasteners that would be interchangeable with the same thread specifications. The DIN standards seem to be the ones that were most favored and were adopted as the ISO standards. As you mentioned, the main shift in the JIS screws was in the change from the previous JIS thread diameter and thread pitch to the now standard ISO specifications. This affected the smaller size fasteners the most, as far as the JIS screws were concerned. The more common sizes of 6 - 1.00, 8 - 1.25, and some others, were not affected.
One of the differences was in the 5mm diameter screw where the previous JIS Standard of 5mm diameter and 0.75mm thread pitch became the same as the DIN or ISO 5mm diameter and 0.8mm thread pitch.
This is where the distinction becomes important. At this point, to distinguish between the earlier JIS Thread Specification and the newer ISO Thread Specification, they added to the head of the fastener, or the side of the nut, the "dot" or "dimple" or small round recess to show that this is the new fastener, and not the older JIS Thread Specification. The form of the head of the fastener did not change; it is still the JIS head using the JIS tooling for installation and removal. Only the thread form or thread specification changed. This is the significance of the "dimple" on the head of the JIS fastener.
TA-125
My experience is with a medication dispensing machine made by Yuyama of Osaka Japan. After servicing almost everything medical and laboratory related, and up until 6 years ago I had never even known about other kinds of Phillips, then during the service training on these units along came JIS as they called it. Each screw has a dimple which I take to understand to indicate that the cross-point head is not a Phillips. The screws are also metric for sure.
We're using JIS screwdrivers available at RC Helicopter hobby shops as that is a common problem with the RC Toys. Most helicopter blades appearantly are held on by JIS screws. Phillips just tears the recess apart.
Further I hunted the net to see about the ISO cross-point screws you mentioned. I can't find them anywhere, just nothing. I did find a lot about ISO metric threads. But never in reference to the head drive recess. Also nothing about ISO screwdrivers as I'd expect.
Unfortunately googling screw heads in several differing searches I could not find a decent picture of the dimple on the head. I'm attaching a pix I took of a few of mine.
Thanks for the information, I'm in the stages of a re-write covering over 100 different screw recess designs (for those that thought they had an extensive bit collection LOL).
